Guides
Upgrades
You can cost-effectively upgrade a number of components in the iMac G4.
  • Memory: iMac G4 PowerMac 4,2 came with 128MB or 256MB standard. Upgrading to the maximum of 1 GB will improve performance, and can be done very easily by installing two 512 MB sticks of RAM, one external RAM stick, and one internal RAM stick.
  • Hard Drive: A 40 GB Ultra ATA/66 hard drive came standard with the iMac G4 PPC 4,2. You can upgrade all the way up to a 128 GB hard drive.
  • Optical Drive: The standard optical drive shipped with iMac G4 PPC 4,2 is either a 10x CD-RW or a 10x CD-RW/"Combo" . The optical drive can easily be upgraded to a SuperDrive.
  • AirPort Card: The iMac G4 PPC 4,2 offered an optional 802.11b AirPort card. If a particular iMac was not built with one, it can easily be installed later.
Background
Originally known as "The New iMac", and Priced between US $ 1299 and US $ 1499, the iMac G4 was created to replace the iMac G3 as Apple's all-in-one desktop computer. Apple advertised that its LCD screen had the flexibility of a desk lamp, giving it the nickname "iLamp". It was produced from the beginning of 2002 until mid 2004, when it was replaced by the iMac G5. The G5 omitted the dome shaped case at the bottom, and placed all of its components within the casing of the monitor. Today, the iMac G4 is still valued somewhere between US $200 to US $ 350 dollars.
Identification
If you're unsure of which particular model you have, follow the identification system steps to find out before following any repair guides, or purchasing any replacement parts.
Technical Specifications
Processor
  • 700 MHz
  • PowerPC 7441 (G4)
RAM
  • PC133 SDRAM
  • Standard 128MB, 256MB
  • Max 1GB
  • Ram Slots: 2
Video Card
  • GeForce2 MX
  • VRAM type DDR SDRAM
Display
  • Build-in 15"
  • Resolution 1024x768
  • Second display mirroring only
Networking
  • AirPort 802.11b (Optional)
  • Standard Ethernet 10/100Base-T
Peripheral Ports
  • 3 USB 1.1 ports
  • 2 FireWire 400 ports
Operating System
  • Pre-Installed 9.2.2 & X 10.1.2
  • Maximum X 10.4.11
Dimensions
  • 12.95 x 15.1 x 10.6*
Weight
  • 21.3 lbs. (9.7 kg)
Additional Information
Ryan Kozak
1,783 Reputation
3 Guides authored
Cal Poly, Team 5-32, Amido Fall 2011 Member of Cal Poly, Team 5-32, Amido Fall 2011
CPSU-AMIDO-F11S5G32
4 Members
96 Guides authored
Past 24 Hours: 9
Past 7 Days: 55
Past 30 Days: 375
All Time: 67,633
