Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background Information
Released in early 2021, the Audient iD14 MKII is a compact 10-in 6-out USB audio interface. It’s the second generation of the original iD14, which was launched in 2015. The iD14 MKII features two fully analog Audient Console Mic Preamps, Advanced 32-bit AD/DA converters, and the option to expand via ADAT iD14 packs. Key upgrades included USB-C 3.0 connectivity, improved headphone outputs, and 125.5dB dynamic range.
Technical Specifications
General Information
  • Announced: January 2021
I/O
  • 2 x Channel Knobs (Mic/Line Input)
  • 2 x Phantom Power Switches
  • 1 x Volume Knob
  • LED Main Meter
  • Main Output Select Button
  • iD Button
  • Headphone Output Select Button
  • USB-C 3.0 Connection
  • ADAT Optical Input
  • 2 x Speaker Outputs
  • 2 x Mic Line Inputs
  • Instrument Input
  • Dual Headphone Outputs (3.5mm and 6.35mm)
D.I/Instument Input
  • Range: +58dB
  • Linup: 12dBu = 0dBFS
  • THD+N @ 0dBu: 0.1%
  • SNR: 100dBu A-Weighted
  • Frequency Response - Min Gain: ±0.5dB 10Hz to 20kHz
  • 1/4” TS Jack: Tip (Hot) & Sleeve (Shield)
Microphone Preamplifier
  • Gain Range: 58dB
  • Lineup: 12dBu = 0dBFS
  • Mic Max Input Level: 12dBu
  • Max Input Level: 21dBu
  • Input Impedance (Mic): 2.8k
  • Input Impedance (Line): >8k
  • THD+N @ 0dBu: 0.00170%
  • THD+N @ 0dBu Max Gain: <0.04%
  • SNR: 101dBu A-Weighted
  • EIN: 129dB A-Weighted
  • CMRR @ 1k:>75dB
  • Crosstalk: >-100dB
  • Frequency Response - Min Gain: ±0.5dB 10Hz to 40kHz
  • Phantom Power: (48V +/-4V @ 10mA/Channel)
  • XLR Combi Female: Pin 2 (Hot), Pin 3 (Cold) & Pin 1 (Shield)
  • 1/4" TRS Jack: Tip (Hot), Ring (Cold) & Sleeve (Shield)
Analogue to Digital Converter
  • THD+N @ -1dBFS: 0.001%
  • Dynamic Range: 120dB A-Weighted
  • CMRR: >80dB
  • Frequency Response: ±0.5dB 10Hz to 40kHz
Line Outputs (DAC)
  • THD+N @ -1dBFS: 0.0006%
  • Dynamic Range: 125.5dB A-Weighted
  • Crosstalk: >120dB
  • Frequency Response: ±0.1dB 10Hz to 40kHz
Headphone Outputs
  • Lineup: 18dBu = 0dBFS
  • THD+N @ -1dBFS: 0.0009%
  • Crosstalk: >116dB
  • Frequency Response: ±0.25dB 10Hz to 40kHz
  • Max Level @ 30R: 2.59V Peak, 1.827V RMS, 223mW
  • Max Level @ 62R: 4.18V Peak, 2.95V RMS, 280mW
  • Max Level @ 600R: 7.72V Peak, 5.46V RMS, 100mW
  • 1/4” TRS Jack: Tip (Left), Ring (Right) & Sleeve (Shield)
USB-C High Speed
  • MIN Requirement: 0.9A @ 5V >=USB 3.0 Port
  • MAX Requirement: 1.5A @ 5V USB-C: Provides higher headphone outputs levels
  • No. of Input Channels: 10
  • No. of Output Channels: 6
  • DSP Mixer Latency Round Trip (in-to-out): 44.1kHz 0.65mS
  • DSP Mixer Latency Round Trip (in-to-out): 48.0kHz 0.6mS
  • DSP Mixer Latency Round Trip (in-to-out): 88.2kHz 0.33mS
  • DSP Mixer Latency Round Trip(in-to-out): 96.0kHz 0.31mS
Physical Dimensions
  • Length: 4.72 in (120 mm)
  • Width: 6.81 in (173 mm)
  • Height (without knobs): 1.57 in (40 mm)
  • Height (w/ knobs): 2.44 in (62.1 mm)
Features
  • 2 x Audient Console Mic Pre’s
  • Class Leading Converters
  • 1 x JFET Instrument Input
  • 4 x Line Outputs
  • ADAT Input for Expandability
  • Ultra Low Latency Software Mixer
  • Advanced Monitor Control
  • Scrollcontrol
  • True Phantom Power over USB
  • USB 3.0 Bus Powered
  • All Metal Design
  • Free Software + Plugins
  • Kensington Lock Hole
What's in the Box
  • iD14 MKII
  • USB-C to USB-c Cable
  • Quic Start Guide
Additional Infomration
Author
with
Jacob Mehnert
50,876 Reputation
52 Guides authored
iFanatics Member of iFanatics
Community
71 Members
1,152 Guides authored
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 69
All Time: 596
