Medical Equipment
Neither iFixit nor this repair information is endorsed by or affiliated with the medical device manufacturer.
Guides
Documents
Troubleshooting
For additional help on the Zoll Impact Uni-Vent 731, check out the device's troubleshooting.
Background and Identification
Designed to meet military and civilian transport standards, the versatile Impact Uni-Vent® 731 EMV+ portable critical care ventilator is ideal for air medical and ambulance transport of infants (≥5 kg), pediatric patients, and adults. The EMV+ is lightweight yet rugged and features an energy-efficient integrated, high-flow compressor and oxygen system.
Source: https://www.mmemed.com/zoll-ventilators/...
Specifications
General
  • Size: 8.0” wide x 12.5” high x 4.5” deep (20.3 cm wide x 31.8 cm high x 11.4 cm deep)
  • Weight: 9.7 lbs (4.4 kg)
Clinical Specifications
  • Operating Modes: AC, SIMV, CPAP, BL
  • Breath Target: Volume and pressure
  • Special Functions: Plateau Pressure, Manual Breath, Apnea Backup, Oxygen in Use, Inverse Ratio
  • Flow Rate: 0 to 100 LPM @ 40 cm H2 O
  • Breath Rate: 1 to 80 BPM
  • Tidal Volume: 50 to 2000 ml ATPD ± 10% of setting
  • Inspiratory Time: 0.3 to 5.0 seconds
  • I:E Ratio: 1:99 to 4.0:1.0
  • FiO2 : 21 to 100% ± 3% of full scale ± 10% of setting
  • PEEP: 0 to 30 cm H2 O
  • Pressure Support: 0 to 60 cm H2 O
  • Peak Inspiratory Pressure (PIP): 10 to 80 cm H2 O
  • Trigger Sensitivity: -0.5 to -6.0 cm H2 O
  • Oxygen Input Pressure: 55 psig (-25%; + 20%) (380 kPa)
Safety Specifications
  • Airway Pressure High Limit: 20 to 100 cm H2 O values
  • Airway Pressure Low Limit: Off, 3 to 35 cm H2 O
  • BPM High Alarm Limit: Off, 2 to 99
  • BPM Low Alarm Limit: 2 to 40
  • LED Status/Alarm Indicator: Red, yellow, and green LCD/LED adjustable
Environmental
  • Operating Voltages: 100 to 240 VAC (50/60 Hz) or 12.5 to 28.0 VDC
  • Operating Time: Internal battery 10 hours
  • Temperature Ranges:
    • Operating: -25° to 49°C (-13° to 120°F) with battery charging, battery discharge and AC power operation
    • Battery Charging: 0° to 45°C (32° to 113°F)
    • Long-Term Storage: -15° to 21°C (5° to 71°F) Optimal storage conditions
Source: Zoll Impact 731 Series Specs
Additional Information
Zoll Offical Website
Zoll Ventilators on Master Medical Equipment
Zoll Simplified Guide
731 Series Ventilator Service Manual
Justin Ogihara
31,653 Reputation
52 Guides authored
Past 24 Hours: 4
Past 7 Days: 8
Past 30 Days: 46
All Time: 1,671
