Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
General parameters
Brand: Xiaomi
Model: Mop 2 Pro
Color: White
Functions: Sweep, Vacuum, Mop, Scrub
Technical parameters
Navigation system: LDS
Scrubbing system: High-frequency sonic vibration
Maximum suction level: 3000 Pa
Dust tank capacity: 450 ml
Battery capacity: 5200 mAh
Rated voltage: 14.4V
Rated power: 35.6W
Battery capacity: 5200mAh
Charging voltage: 20V
Other features and functions
Climbs obstacles: Yes, up to 20 mm
Control via APP: Yes, Xiaomi Home
Compatible with Amazon Alexa: Yes
Compatible with Google Assistant: Yes
Dimensions and weight
Dimensions: Φ353 x 96.5mm
Weight: 3.6kg
Charging base
Rated input: 100-240 V, 50/60 Hz, 0.8 A
Dimensions: 150 x 80.5 x 101 mm
Rated output: 20V⎓1.8A
Mi Robot Vacuum-Mop 2 Pro User Manual
Author
with
FatihAlper
28 Reputation
0 Guides authored
Past 24 Hours: 3
Past 7 Days: 34
Past 30 Days: 200
All Time: 1,494
