Up to 20% off select tools
Processor
MediaTek Dimensity 9200+
4nm power-efficient manufacturing process
CPU:
1x Arm Cortex-X3, up to 3.35GHz3x Arm Cortex-A715, up to 3.0GHz4x Arm Cortex-A510, up to 2.0GHz
GPU: Arm Immortalis-G715
Storage & RAM
12GB + 256GB, 12GB + 512GB, 16GB + 1TBLPDDR5X RAM + UFS 4.0 storage*Available storage and RAM are less than the total memory due to storage of the operating system and software pre-installed on the device.
Dimensions
Glass:
162.2mm x 75.7mm x 8.49mm I PU: 162.2mm x 75.7mm x 8.62mm Data tested in Xiaomi Internal Labs, actual results may vary.Glass: 206g I PU: 200g Data tested in Xiaomi Internal Labs, actual results may vary.
Display
Flat displayFHD+ 6.67" AMOLED20:9, 2712 x 1220446 ppiUp to 144Hz refresh rate* The screen supports a maximum refresh rate of 144Hz. The screen refresh rate may be slightly different under different application interfaces and game image quality. Please refer to the actual experience.AdaptiveSyncTouch sampling rate: up to 480 Hz Touch sampling rate may vary according to the content on your display.Brightness: HBM 1200 nits (typ)* , 2600 nits peak brightness* *Data tested in Xiaomi Internal Labs, actual results may vary.16000 level brightness adjustmentPro HDR display |Dolby Vision® |HDR10+ | HDR10Color gamut: DCI-P3 |68 billion colors |True DisplayTrueColor display: JNCD≈ 0.32, Delta E≈ 0.37* *Data tested in Xiaomi Internal Labs, actual results may vary.2880Hz PWM dimming |Adaptive reading mode |Sunlight mode |Corning®️ Gorilla®️ Glass 5
Rear camera
Leica professional optical lens
LEICA VARIO-SUMMICRON 1:1.9-2.2/15-50mm ASPH.
Leica main camera
1/1.28” sensor size50MP1.22μm pixel size, 2.44μm 4-in-1 Super Pixel24mm equivalent focal lengthf/1.9OISIMX707ALD7P lensAF
Leica telephoto camera
50MP1/2.88” sensor size0.61μm pixel size50mm equivalent focal lengthf/1.95P lensAFOV50DUp to 20x digital zoom
Leica ultra-wide camera
12MP1/3.06" sensor size1.12µm pixel size15mm equivalent focal lengthf/2.2FF5P lens
Rear camera photography features
Two Leica photographic styles
Leica Authentic LookLeica Vibrant LookLeica custom photographic stylesLeica filtersLeica classic shutter soundLeica watermarkMaster-lens system35mm Documentary lens50mm Swirly bokeh lens90mm Soft focus lens
Xiaomi Imaging Engine
Xiaomi ProFocus (Motion tracking focus / Motion capture)Xiaomi ProCutLightning BurstUltra Night PhotoNight mode (wide/ultra wide/telephoto)HDRDigital zoom up to 20x50MP mode (wide/telephoto)Slow motionPanoramaDocumentsLong exposurePro modeImage formats captured: HEIF, JPEG and DNGRAW mode
Video Recording
HDR video recording with HDR10+ up to 4K at 30 fps8K (7680x4320) video recording at 24fps4K (3840x2160) video recording at 24 fps, 30 fps, or 60 fps1080p (1920x1080) HD video recording at 30 fps, or 60 fps720p (1280x720) HD video recording at 30 fps10-bit Log video recordingXiaomi ProFocus (Motion tracking focus)Steady videoMovie frameTeleprompterUltra Night VideoShort filmSlow motion video: 120fps, 240fps, 960fpsVideo pro mode
Front camera
20MP front camera
f/2.20.8μm pixel size78° FOV5P lens
Front camera photography features
Night modeHDRPortrait modePalm ShutterTimed burstMovie frameSelfie timer
Front camera video features
HDR video recording with HDR10+ up to 1080p at 30 fps1080p (1920x1080) HD video recording at 30 fps720p (1280x720) HD video recording at 30 fpsTeleprompterShort filmSlow motion video: 120fpsTime-lapse
Battery & Charging
Xiaomi Surge Battery Management systemXiaomi Surge charging chipsetXiaomi Surge battery management chipset120W HyperCharge 19 mins to 100% (Boost mode) 24 mins to 100% (Standard mode)*Charging data tested in Xiaomi Internal Labs, actual results may vary.USB type-c5000mAh (typ) batteryUp to 17 hours video playbackUp to 5 hours 1080p video recordingUp to 73 hours music playback
Cooling system
LiquidCool Technology (5000mm2 stainless steel VC + Multi-layer graphite sheets)
Security & Authentication
In-screen fingerprint sensorAI face unlock
NFC
Yes
Network & Connectivity
Dual SIM (nano SIM + nano SIM or nano SIM + eSIM) Use of eSIM requires a wireless service plan. This service plan may be subject to certain restrictions of use on switching service providers and roaming (even after contract expiration). eSIM availability may vary depending on country/region and carrier. For more details, please contact your carrier for more information.https://www.mi.com/global/support/esim
5G: Supports NSA + SA
5G: n1/3/5/7/8/20/28/38/40/41/66/75/77/784G: LTE FDD: B1/2/3/4/5/7/8/12/13/17/18/19/20/25/26/28/32/664G: LTE TDD: B38/39/40/41/42/483G: WCDMA: 1/2/4/5/6/8/192G: GSM: 850 900 1800 1900 MHz5G connectivity may vary based on region availability and local operator support.
Wireless NetworksWi-Fi 7/Wi-Fi 6E/Wi-Fi 6 capability
Wi-Fi 7/Wi-Fi 6E/Wi-Fi 6 capability may vary based on regional availability and local network support.Wi-Fi connectivity (including Wi-Fi frequency bands, Wi-Fi standards and other features as ratified in IEEE Standard 802.11 specifications) may vary based on regional availability and local network support. The function may be added via OTA when and where applicable.Supports 2.4GHz Wi-Fi / 5GHz Wi-Fi / 6GHz Wi-Fi* Frequency bands may vary based on regional availability and local network support.Supports 2x2 MIMO, 8x8 Sounding for MU-MIMO, WiFi DirectBluetooth 5.4Supports AAC/LDAC/LHDC/ASHA
Navigation
GPS: L1+L5Galileo: E1+E5a | GLONASS: G1 | Beidou| NavIC: L5A-GPS supplementary positioning | Wireless network | Data network| MPE
Audio
Dual speakersDolby Atmos®
Audio playback
Supports audio formats such as MP3, FLAC, APE, AAC, OGG, WAV, AMR, AWBHi-Res Audio certification
Video playback
MP4丨MKV丨WEBM丨3GPSupports HDR display when playing HDR10, HDR10+, Dolby Vision video content
Splash, Water & Dust Resistance
IP68
Disclaimer: *The device has been tested and certified to be resistant to splash, water, and dust in the presence of specific laboratory conditions with the classification IP68 ingress protection based on IEC 60529:1989+A1:1999+A2:2013. Please be noted that the test conditions of water resistance include: submersion in static freshwater up to a depth of 1.5 meters, up to 30 minutes, with a temperature delta between the water and product being 5K or less. Such water resistance features only pertain to specific conditions tested in a laboratory environment, which do not correspond to the normal conditions of use by consumers. Therefore, ingress protection is not assured if the product is subjected to environments beyond the test conditions. We recommend that you do not test it by yourself. Not advised for beach or pool use. Ingress protection might deteriorate from daily wear and tear, physical damage and/or disassembly needed in case of repair. Avoid charging the product, operating the physical buttons, or removing the SIM tray when product is exposed to moisture. Please carefully refer to user's manual for other safety instructions. The warranty will not cover the liquid damage caused in the environments beyond the IP68 test condition.
Sensor
Proximity sensor | 360° Ambient light sensor | Accelerometer | Gyroscope | Electronic compass | Linear motor | IR blaster | Flicker sensor |Color sensor
Vibration motor
X-axis linear vibration motor
Operating system
MIUI 14, android 13
Felix Klute
5,804 Reputation
0 Guides authored
iFixit EU Team Member of iFixit EU Team
Staff
36 Members
3,072 Guides authored
Past 24 Hours: 7
Past 7 Days: 57
Past 30 Days: 199
All Time: 7,052
