Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background and Identification
The XMAX V3 Pro is a type of portable vaporizer. It is designed for use with dry herbs and features a ceramic heating chamber and a convection heating system. The device has a digital display that shows temperature and battery level, and it can be adjusted to a range of temperatures. The XMAX V3 Pro has a removable battery. It also has a vibration feature that alerts the user when the device has reached the desired temperature.
Specifications
Height: 5.91 in / 15 cm
Width: 1.05 in / 2.5 cm
Depth: 0.94 in / 2.3 cm
Weight: 3.7 oz / 105 g
Temperature range: 212°F - 428°F (100°C - 220°C)
Battery capacity: 18650 3.7V 2600mAh
Charging: USB-C
Colors: Black, Silver, Green, Purple
XMAX V3 Pro Instruction Manual
XMax V3 Pro Instruction Manual
XMAX V3 Pro Instruction Manual (EN, PL, DE)
Author
with
ShellingRook27
2,383 Reputation
7 Guides authored
Repair For You Member of Repair For You
Business
1 Member
84 Guides authored
Past 24 Hours: 1
Past 7 Days: 49
Past 30 Days: 167
All Time: 5,673
