Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background and Identification
The My Book Essential Edition is an external hard drive with USB 2.0 (max 480 Mbit/s) connectivity. The drive was released by Western Digital in 2006, and was designed to mimic the appearance of a hardback book. The outer case of each model is the same (although they may vary slightly in size), but the hard drive inside comes in 80, 160, 250, 320, 400, 500, and 750 GB versions according to the WD support website.
The blue LED on the front of the case will light up when the drive has power and will blink when the drive is active. Fun fact: the vents on the top of the case spell out words in Morse code. Although the device is sold as a combination of a hard drive and external case, the 3.5-inch hard drive inside can be exchanged relatively easily. The drive is powered with an external power supply through the barrel jack on the back of the case.
This device can be identified by looking at the back of the case, where the words “My Book Essential“ should be written. You can check the model number—which is also printed on the back of the case—against this list on the WD support website.
Technical Specifications
Connections
  • USB 2.0 port
  • DC barrel jack (12 V, 1.5 A)
  • Kensington Security Slot
Hard Drive
  • Capacities: 80, 160 GB, 250 GB, 320 GB, 400 GB, 500 GB, 750 GB
  • Size: 3.5 inches
  • Speed: 7200 RPM
Additional Information
User manual
Marketing pamphlet
WD support page for the Essential Edition
Amazon: My Book Essential
Wikipedia: My Book
Author
with
Taylor Arnicar
13,397 Reputation
0 Guides authored
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 75
All Time: 25,475
