Up to 20% off select tools
Guides
3 Diagrams
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
PST2 400
Background and Identification
The Wacker Pump model PST2 400 (model number 0620435) is a single-phase electric submersible utility pump. It can handle up to 0.4-inch solids for dewatering of excavations, flooded basements, utility vaults, swimming pools, lakes, manholes, or wherever there is unwanted water. The pump includes a 2-inch motor and an oil-filled cavity that keeps the motor lubricated. Built-in thermal protection prevents damage to the motor due to impeller blockage.
The PST2 400 model includes silicon carbide-face double mechanical seals that run in the oil-filled motor cavity and allow seal lubrication, cooling, and overall motor protection. The pump includes a 20-foot electrical cord and has maximum discharge flow of 3180 gallons per hour. It uses a 0.5-horsepower motor to move water with some submerged solids. PST models feature shaft-mounted agitators which are designed to suspend solids when pumping water containing sand and debris.
The PST2 400 model includes aluminum housing and a threaded male outlet connection. It includes a yellow motor casing and a black float. A black and silver handle is positioned at the top of the pump’s body for carrying and positioning the machine. A black sticker with white font is included on the top of the pump’s yellow body that includes identification information like the machine’s model number.
Technical Specifications
Dimensions:
  • Product Depth (in.): 7.3
  • Product Height (in.): 10.1
  • Product Width (in.): 13
Details:
  • Amperage (amps): 5.4
  • Cord Length (ft.): 20
  • Discharge Flow @ 0 ft. (gallons/hour): 3780
  • Discharge Flow @ 0 ft. (gallons/min): 63
  • Discharge Flow @ 10 ft. (gallons/hour): 3360
  • Discharge Flow @ 10 ft. (gallons/min): 56
  • Head Pressure (ft.): 39
  • Housing Material: Aluminum
  • Maximum Discharge Flow (gallons/hour): 3180
  • Maximum Horsepower (hp): 0.5
  • Maximum Pressure (psi): 52.8
  • Maximum Working Temperature (F): 111
  • Minimum working temperature (F): 40
  • Outlet Connection: Threaded male
  • Power Type Required: AC
  • Product Weight (lb.): 25lb
  • Pump Switch Type: Switchless
  • Vertical Lift (ft.): 39
  • Voltage: 110v
Additional Information
Pompe PST2 400 — Notice d'emploi
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 32
Past 30 Days: 162
All Time: 10,052
