23 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
GP6600
Background
The Wacker Generator GP 6600 is powered by a Honda engine mainly used to power tools for construction, home projects, rental and demanding applications. It includes a step-start generator technology with AVR (automatic voltage regulator), meaning they create a consistent voltage output. This feature protects the generator from the power output changing irregularly.
In July 2021 the Wacker Generator GP6600 has had about 321,160 recalls. With unit numbers GP6500, GP6500E and GP8000E, the reason being that an unlocked handle can pinch consumers fingers against the generator frame when moving the generator, posing finger amputation and crushing hazards. The company for the GP6600 Generator received eight reports of injuries, seven resulting in finger amputations and one in finger crushing. What the company recommends to do is to return the Generator unless the locking pin has been inserted to secure the handle in place before and after moving the generator, and contact Generac for a free repair kit.
Identification
The Wacker Generator GP6600 has a very symmetrical shape, characterized by its bright yellow gas tank with gray bars surrounding the machine. There are two wheels placed under the motor with a handle sticking out the opposite side with a rubber grip for better mobilization. On the left side of the GP6600 label where you will also find the control panels, outlets and the on/off switch. It weighs 198 pounds and is 27x21x21.2 inches.
Technical specifications
  • Electrical power Maximum Output 6,600 W
  • Electrical power Continuous Output 6,000 W
  • Voltage AC – 1 Phase 120/240 V
  • Recoil Start
  • Automatic Voltage Regulation (AVR) Technology
  • Central GFCI (neutral bonded to ground) sensor system to eliminate common GFI outlet failures
  • Automatic time-delay system and auto-idle control
  • Wheel kit included for portability
  • Engine / Motor Honda GX390
  • Frequency 60 Hz
  • Circuit breaker AC – 1 Phase 2 Pole 27 A
  • Receptacles (2) 125V, 20A duplex 5-20R
  • Receptacles (1) 125V, 30A twist lock L5-30R
  • Receptacles (1) 125/250V, 30A twist lock L14-30R
  • Operating performance 11.66 hp @ 3,600 rpm
  • Tank capacity Fuel 5.5 US gal
  • Fuel Type: Gasoline
  • Fuel consumption 1 gal/h
  • Runtime 5.4 h
  • Operating Weight: 223 lbs
  • 3-Year Warranty
  • Length: 20.6"
  • Width: 27.5"
  • Height: 24.1"
  • Fuel tank capacity: 7.9 gal US
Additional Information
https://www.gardenland.com/product/wacke...
https://www.manualslib.com/products/Wack...
https://www.dowdsupplycompany.com/Wacker...
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 89
All Time: 1,025
