24 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background and Identification
The Wacker Concrete Vibrator VP1550AW/WH was released in 2018. It is designed and manufactured by Wacker Neuson SE, a company that specializes in construction equipment, particularly concrete and construction site technology. They are based in Munich, Germany.
Concrete vibrators are necessary to remove air pockets or bubbles that may remain when concrete is poured, in order to maintain the integrity of the concrete. They work by shaking the poured concrete which increases its strength and density.
The Wacker Concrete Vibrator is a very lightweight tool. It has a powerful aluminum engine console and belt guard and is easily adjustable. It has different lifting styles to use when loading and unloading. The water tank is in the front lift cage and can be easily checked for safety. The Wacker Concrete vibrator water filter prevents clogging and is easily removable for cleaning and draining.
Technical Specifications
Length x width x height (handle in working position): 40 x 19.5 x 35 in
Lowest working height26.7 inSize of base plate (L x W): 23 x 19.5 in
Operating weight:184 lbs | 83 kg
Compacted area (soil): up to 9,365 ft2/h
Forward speed (soil): up to 67 ft/min
Max. Grade: 30%
Vibration frequency: 97 Hz
Max. centrifugal force: 3,375 lb
Engine Type: Honda Gas Air-cooled, 4 cycle, single cylinder
Displacement: 9.9 in3
Rated power output (@3600 rpm): 5.0 hp
Fuel tank capacity: 0.95 US gal
Run Time: 4.75 hr
Power Train: Centrifugal clutch and V-belt onto exciter which transmits centrifugal force onto baseplate.
Additional Information
Wacker Neuson Equipment
Wacker Neuson Group
Wacker Neuson Wikipedia
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 52
All Time: 1,496
