Medical Equipment
Neither iFixit nor this repair information is endorsed by or affiliated with the medical device manufacturer.
Documents
Background and Identification
This is an infant flow SiPap system that raises the bar for neonatal noninvasive ventilation. This device has been successfully, clinically proven among patients worldwide. It comes with a patented generator technology that is safe and versatile while offering advanced noninvasive treatment options (especially geared toward infants). “Nasal CPAP (nCPAP) is a constant, stable, single level os positive pressure to the infant’s airways; facilitating the restoration of functional residual capacity and the correction of hypoxemia.” (Viasys Infant Flow SiPAP Brochure)
The Viasys Infant Flow SiPap Ventilator is colored gray with a light blue plastic casing. It has an advanced monitoring screen system (4.4'“x 3.3”) with a resolution of 320 x 240 pixels. This device can be distinguished by the large “%O2” knob that rests in the middle of the device right above the CareFusion logo.
Technical Specifications
Modes
  • CPAP
  • CPAP with Apneal/LBR
  • BiPhasic
  • BiPhasic with Apneal/LBR
  • BiPhasic tr
Alarms
  • High Pressure
  • Low Pressure
  • Hi FiO2
  • Low FiO2
  • Low Battery
  • Low Breath Rate
Monitored Parameters
  • nCPAP: 0 to 11 cmH2O
  • MAP: 0 to 15 cmH2O**
  • PIP: 0 to 15 cmH2O**
  • PEEP: 0 to 15 cmH2O**
  • %O2: 21% to 100%
Controls
  • nCPAP/Pressure Low Flow Meter: 0 to 15 L/min
  • Pressure High Flow Meter: 0 to 5 L/min
  • %O2: 21% to 100%
  • Inspiratory Time: 0.1 to 3.0 seconds
  • Backup Rate: 1 to 120 bpm
  • Rate: 1 to 120 bpm
  • Apnea Interval (T-Apnea): 10 to 30 seconds (5 second intervals)
  • Manual Breath
Power Supply
  • 100 to 230 VAC; consumption 50 VA maximum
  • 12 VDC (sealed lead acid battery); 2 hour life with full charge
Dimensions/Weight (Driver Only)
  • 10.25'“ x 15” x 9.25” (26 cm x 38 cm x 23.5 cm)
  • 19.5 lbs. (8.8 kg)
Monitor Screen
  • 4.4” x 3.3” (11 cm x 8 cm)
  • Resolution: 320 x 240 pixels; 1/4 VGA with auto-dimming backlight
Sources
Information extracted from the Viasys Infant Flow SiPAP Spec Sheet
Additional Information
Jeff Stephens
280,774 Reputation
0 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,931 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 49
All Time: 1,688
