Up to 20% off select tools
Medical Equipment
Neither iFixit nor this repair information is endorsed by or affiliated with the medical device manufacturer.
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background and Identification
The Ventec One Circuit is a ventilator that possesses multiple functions in order to deliver integrated therapy to patients. The Ventec One Circuit functions as five devices, including a ventilator, nebulizer, and oxygen concentrator. It also provides touch-button cough and suction to patients with respiratory problems. The device received FDA clearance on April 12th, 2017 to begin functioning as a multi-function ventilator for patients. The intended users for this product include those with respiratory ailments, neuromuscular disease, a spinal cord injury, an impaired lung function, and pediatric development complications.
The Ventec One Circuit is a small box-shaped device that only weighs 18 pounds. It is encased in a dark thermoplastic that is tough and durable. A power button is provided in the bottom right-hand corner. It also includes a port on the right hand side in order for the insertion of the circuit. A software screen is provided on the front of the device in order for users to interact with the machine. An additional button is also available on the front of the device to switch between the five functions that are provided.
Source: Ventec Life Systems
Technical Specifications
Patients
  • Invasive and non-invasive ventilation (including mouthpiece)
  • Adult and pediatric patients greater than 5 kg
Dimensions
  •  Width: 10.25 inch (26 cm)
  • Height: 11 inch (28 cm) o
  • Depth: 7.5 inch (19 cm)
Battery power
  • Up to 9 hours of continuous use (ventilation only)
  • 2 external hot swappable lithium-ion batteries (5,800 mAh each)
  • 1 Internal battery (3,900 mAh)
  • Note: Simultaneous use of therapies will decrease battery operating time
Power Sources
  •  AC (wall plug-in)
  •  DC (wheelchair and external batteries)
  • VOCSN Batteries (3 batteries: 15,500 mAh total)
Power Environment
  • Temperature: 5 °C to 40 °C
  • Humidity: 15% to 90% (non-condensing)
  • Atmospheric: 700 to 1060 hPa
Alarm Volume
  •  65 to 85 decibels
Source: vocsn_tech-specs_current.pdf (venteclife.com)
Additional Information
Ventec Life Systems
Ventec One-Ciruit — Trace Medical
Ventec Life Systems Vocsn V+Pro Clinical And Technical Manual (Page 4 of 194)
Author
with
Justin Ogihara
31,780 Reputation
52 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 22
All Time: 663
