Up to 20% off select tools
Documents
The temperature control is not set to any measured temperatures, but merely has an unmarked analogue dial similar to an electric radiator thermostat.
Since there are no wires to a thermistor or similar in the hot-end, and the dial ‘clicks’ on at the lowest point of the dial, an educated guess is that this controller uses some kind of PWM to drive a power level determined by the position of that dial on a potentiometer. Hence no temperature markings, as the resulting tip temperature will depend on environmental conditions.
Velleman VTSS5 Temperature-Controlled Soldering Station User Manual (EN, NL, FR, ES, DE)
Author
with
Andrew Drummond
76 Reputation
0 Guides authored
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 68
All Time: 2,133
