No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
01903-0
Background
The Troy-Bilt 020208 is a brass water pump specifically designed for use with certain models of Troy-Bilt pressure washers. It is capable of reaching a maximum pressure of 3000 psi, which makes it suitable for a variety of residential pressure washing tasks. The pump is built with a brass exterior and operates on an axial cam mechanism. In terms of connectivity, it utilizes a standard garden hose thread for the water inlet, while the outlet thread size is M22 - 14mm. The pump doesn't have an independent electric motor and is powered by a horizontal shaft gas engine or electric motor that is part of the pressure washer. The dimensions of the pump are 8.58 x 8.19 x 7.6 inches and it weighs 7.69 pounds.
The Troy-Bilt 020208 pump serves as a replacement pump for certain Troy-Bilt pressure washers that have faulty or worn-out pumps. It doesn't come with its own electric motor, instead, it attaches directly to the engine or motor shaft of the pressure washer. The pump's water supply is connected through a standard garden hose at the inlet. The outlet, on the other hand, has a M22 14mm thread that can be connected to the pressure washer wand and hose. The models of Troy-Bilt pressure washers that this pump is compatible with include the Troy-Bilt 020296, 020296-0, 020344, 020345, 020375, and 020375-0.
Technical Specifications
  • Model Number: 020208, 020208-0, 020208-01
  • Product: Troy-Bilt Pressure Washer Pump
  • Product Type: Pressure Washer Pump
  • Pump Material: Brass
  • Exterior Finish: Brass
  • Output Pressure: Up to 3000 psi
  • Pump Type: Axial cam
  • Inlet Thread Size: Standard garden hose thread
  • Outlet Thread Size: M22 - 14mm
  • Voltage: N/A (no electric motor)
  • Dimensions: 8.58 x 8.19 x 7.6 inches
  • Weight: 7.69 pounds
Warranty
The Troy-Bilt 020208 pump comes with a limited warranty provided by the manufacturer. This warranty covers defects in materials and workmanship for a period of 90 days from the date of purchase. However, it is important to note that this warranty is strictly limited to residential use only. In terms of what the warranty covers, it is specifically for the pump itself and does not extend to cover labor costs for installation or replacement. To claim the warranty, you should contact the manufacturer, Troy-Bilt, directly, presumably with proof of purchase and details of the defect.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 37
All Time: 558
