Up to 20% off select tools
Documents
These heaters are ETL approved for permanent installations and electrical connections. Built with splash proof construction, the conducting parts are protected against water. All wiring must be performed in accordance with national and local codes. See Diagram2for wire and room size requirements. These heaters are wall mounted.
The NTSA series sauna heater is equipped with NTS-100 on-heater digital control panel while the NTSC series sauna heater is equipped with NTS-300 wall-mounted digital control panel. Control panel NTS-300and NTS-100 are designed for family use only.
NTSA and NTSC series sauna heaters are designed for small sauna rooms.
NTSA 30-90: 17 3 /4” W×15” D×24 3 /4”H
NTSC 30-90: 17 3 /4” W×11 3
Author
with
nicO
15,990 Reputation
88 Guides authored
Global Fixers Member of Global Fixers
Community
74 Members
3,048 Guides authored
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 115
All Time: 2,381
