Guides
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Toshiba Satellite E45-B4100 was first introduced on March 4th, 2015. It has a 5th generation Intel Core ™ i5-5200U processor that has a speed of 1.7 GHz with 6GB DDR3 SDRAM, it also has a 750 GB ATA hard drive that runs up to 5400 rpm. It has two 3.0 USB ports and one 2.0 port. It is running on a Windows 8.1 operating system, with a Bluetooth 4.0 interface, and a backlit keyboard.
Identification
It weighs 4.5 lbs and measures 0.85" thin, featuring a 14’ screen, with a brushed-aluminum finish in satin gold. The Toshiba logo is printed on the lid of the laptop and in the lower left corner of the display bezel, and "Satellite" is printed in the lower left corner of the keyboard palmrest assembly.
You can identify your Toshiba Satellite E45-B4100 by the model and serial numbers printed on a label on the bottom of your laptop.
Additional Information
Toshiba Satellite E45-B4100 Specifications
Toshiba Support
Toshiba Satellite E45-B4100 User's Guide
Toshiba Satellite E45-B4100 on Amazon
Delaney
113 Reputation
1 Guide authored
USF Tampa, Team 1-4, Leahy Fall 2016 Member of USF Tampa, Team 1-4, Leahy Fall 2016
USFT-LEAHY-F16S1G4
3 Members
60 Guides authored
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 48
All Time: 4,317
