Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Models
XT290
Background
The Titan Paint Sprayer XT290 is a low-tier airless paint sprayer designed for contractors, maintenance teams, and property managers. It caters to those who require a sprayer for several large-scale projects each year. The specifications of this paint sprayer include a maximum pressure of 3,000 PSI, flow rate of 0.29 GPM, a power of 120V, 60Hz, and it weighs 30 lbs. Its dimensions are 17.5 x 21 x 34 inches, with a tank volume of 5 gallons and a hose length of 25 ft. The sprayer uses an XT-05 metal contractor-grade spray gun and includes a reversible 415 tip.
The Titan Paint Sprayer XT290 incorporates a QuickFlo valve system that contributes to a quicker pressure buildup. It also includes a Quick-Check lite power cord and an upright cart design with a 5-gallon bucket bracket. The sprayer is equipped with a metal spray gun, a 25 ft hose, and a 415 reversible spray tip that is capable of spraying various coatings. The unit comes with a pressure control knob that is straightforward to use and has onboard storage for the hose and gun. It's designed to spray latex house paints, stains, enamels, block fillers, primers, and textures. The cart assembly is made entirely of metal, which promotes portability across different job sites. Regular maintenance, such as cleaning the filters, changing worn spray tips, lubricating the piston, and inspecting hoses for wear, is required to keep the sprayer functioning optimally.
Technical Specifications
  • Model Number: XT290
  • Product Type: Paint Sprayer
  • Maximum Pressure: 3,000 PSI
  • Flow Rate: 0.29 GPM
  • Power: 120V, 60Hz
  • Weight: 30 lbs
  • Dimensions: 17.5 x 21 x 34 inches
  • Tank Volume: 5 gallons
  • Hose Length: 25 ft
  • Spray Gun: Metal contractor grade
  • Spray Tips: Reversible 415 tip included
Warranty
The Titan XT290 Reconditioned Airless Paint Sprayer comes with a warranty period of 90 days. This warranty covers both parts and labor, ensuring that any necessary repairs or replacements due to manufacturing defects within this period will be taken care of by the company. To claim the warranty, the units are reconditioned at the Titan factory located in Minneapolis, MN. The reconditioning process includes the replacement of worn parts to make sure the performance of the product meets Titan factory standards.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 55
All Time: 1,216
