Up to 20% off select tools
Guides
Documents
Area: Car and Truck > Tesla
Stub: Tesla Chargers and Wall Connectors
These articles applies to Wall Connectors identified by part number ***1457768-**-****
  • 71 km of range added per hour of charging
  • Multiple power settings
  • 7.3m cable length
  • Versatile indoor/outdoor design
  • Power-share to automatically distributing power to charge multiple cars simultaneously
  • Compatible with both Single and Three Phase power
Product Specifications
Voltage and Wiring Nominal 200-240 V AC single-phase
Current Output Range 12 – 48 amps
Terminal Blocks 12-4 AWG (3.5 - 25 mm2), copper only
Supported Conduit Sizing ¾ in (21 mm) default, 1 in (27 mm) optional
Grounding Scheme TN/TT
Frequency 50/60 Hz
Cable Length 7.3 m (24 ft)
Wall Connector Dimensions Height: 13.6 in (345 mm) Width: 6.1 in (155 mm) Depth: 4.3 in (110 mm)
Wire Box Bracket Dimensions Height: 9.8 in (250 mm) Width: 4.7 in (120 mm) Depth: 2.0 in (50 mm)
Weight (including wirebox) 10 lb. (4.5 kg)
Operating Temperature -22˚F to 122˚F (-30˚C to 50˚C)
Storage Temperature -40˚F to 185˚F (-40˚C to 85˚C)
Enclosure Rating Type 3R
Ventilation Not required
Means of Disconnect External branch circuit breaker
Ground Fault Circuit Interrupter Integrated, no additional required (CCID20)
Wi-Fi 2.4 GHz, 802.11b/g/n
Agency Approvals cULus - E351001
Author
with
FleRoY
196 Reputation
1 Guide authored
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 106
All Time: 1,755
