Up to 20% off select tools
Medical Equipment
Neither iFixit nor this repair information is endorsed by or affiliated with the medical device manufacturer.
No Image
This wiki is missing a device image. Help improve this page by uploading one!
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background and Identification
The TSI PortaCount Pro Plus 8030 8038 is a medical device used for measuring the fit efficiency of any tight-fitting respirator. Capable of testing within the range of 1 to greater than 10,000.
Any tight-fitting respirator includes:
OSHA, CSA, HSE and ANSI Compliance for all tight-fitting respirators, including series 95, 99, 100, FFP1, FFP2 and FFP3 filtering facepiece respirators.
For more information
Benefits:
·       Has fewer errors
·       Easy to operate (Automated)
·       Doesn’t require another computer to use
·       Measures fit factors greater than 10,000
·       It has a touchscreen
·       Compatible with new modified CNC Protocols
Details
Manufacturer -TSI
TSI is a company that focuses on creating machines with trustworthy data for users to use.
Physical Attributes
Size: 24 x22 x17 cm (just test machine) 49.5 x34.8x23cm (case size)
Weight: 2.7 kg (with only test machine) 7.3 kg (with all other things in case)
Temperature required: 0 to 35°C
Power required: 100 to 250 VAC, 50 to 60 Hz
Type of alcohol needed: Reagent grade isopropyl (99.5% or greater)
Alcohol refill time: every 6 hours while at room temperature
Manufacturer recalls
Warranty - contain 2 years of workmanship and materials
Frequent problems
Alcohol cartridges can get dirty or leak: see OPERATION AND SERVICE MANUAL page 69
System update or renew: here is the website to help
Different from similar models
Considering model 8030 and 8038 are old the difference between it and the new model 8040 is the new 8040 doesn’t have a built-in black and white screen like model8030 and 8038 but with a new iPad shape screen with colour and bigger for easy handle.
Technical Specifications
The Touch Screen Display:
Twin Tube Assembly :
contain: Sample Port, Ambient Port
length: 1.7 meters long
Electrical Connections contain:
USB Series “B”: used for connection to PC
2 USB Series “A”: use for connection to USB mouse, USB keyboard, compatible USB printer, or a USB flash drive.
External Power Connector: use for connection to AC Adapter
The AC Adapter plugs:
AC Adapter plugs: able to connect to the wall outlet, able to switch plug for a different country.
Alcohol-Related Parts:
Alcohol Cartridge: holds the isopropyl alcohol consumed by the PortaCount Pro fit tester
Storage Cap: use to cover cartridge cavity when not in use
Alcohol Fill Capsule: use to store alcohol and fill the alcohol cartridge
Additional Information
how to maintain
RESPIRATOR FIT TESTER 8030
RESPIRATOR FIT TESTER 8038
Author
with
Justin Ogihara
31,780 Reputation
52 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 30
All Time: 456
