Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Hardware:
CPU: ez80, clocked at 48MHz
RAM: 154KB user-accessible; 256KB total.
Flash (ROM): 3.0MB user-accessible; 4.0MB total.
LCD: 2.8 inch 320x240-pixel (16-bit color), memory-mapped (non-touchscreen)
LCD Controller: PrimeCell PL111 Color LCD Controller
Ports: mini-USB. No DBUS (2.5mm I/O) port. USB IP core is the Faraday FOTG210.
Power: Rechargeable lithium-polymer battery 1200 mAh
Battery Life: 30 hours of continuous use at maximum brightness. "Up to one month" with standard use. Deep sleep feature saves power over months of non-use.
Software:
Operating System (OS): TI-OS 5.x
  • Warning: OS 5.5.1 and higher restricts the ability for the calculator to run programs written in assembly.
Connectivity Software: TI Connect CE
Programming:
  • Official:
    • Assembly
    • Python (only available on Python edition calculators)
    • TI-BASIC
  • Unofficial:
Source:
Cemetech.net
Some users also use online graphing tools to simulate TI-84 functionality for learning and practice purposes.
An example of such a tool is available here: https://ti84calculatoronline.org/
Graphing Calculator Comparison
TI-84 Plus CE Calculator Keypress Instructions
Charging TI-84 Plus CE Handhelds FAQ
TI-84 Plus CE Absolute Value Key Press Guide
TI-84 Plus Family Test Preparation: Clearing Memory and Apps
TI-84 Plus CE Key Press Instructions
TI-84 Plus CE Calculator Key Press Instructions
TI-84 Plus CE-T Python Edition, CE-T en TI-84 Plus Nederlandse Examenstandinstructies
Texas Instruments TI-84 Plus CE Standardized Tests Best Practices
TI-84 Plus CE Absolute Value Keypress Reference
Author
with
o355
609 Reputation
1 Guide authored
Past 24 Hours: 5
Past 7 Days: 33
Past 30 Days: 213
All Time: 27,355
