Battery
1 Answer -1 Score |
Why won't my phone turn on? |
1 Answer -1 Score |
My phone will not turn on |
1 Answer 0 Score |
Screen is black but the touch part still works. |
1 Answer -1 Score |
My phone wont turn on. |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The T-Mobile Huawei Prism is a smartphone manufactured by Huawei and distributed by T-Mobile. The phone was released May 6, 2012, as an inexpensive alternative in the smartphone market. The Prism is the ideal phone for the first time smartphone user.
This phone contains the necessities with a Micro-USB Port, 3.5mm headphone jack, and a rear facing camera. The responsive 3.5 inch touchscreen has a resolution of 320x480 pixels.
In 2013, T-Mobile released the Prism 2 as the successor to the Prism. The phone follows the theme of being inexpensive and easy to use. It boasts an improved 1,750 mAH battery, as well as an improvement in the processor from 600MHz to 1Ghz.
Identification
This device can be identified by model number U8651T.
Upgrade
You can easily improve the memory capacity of your Huawei Prism with a Micro SD Card.
