Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background and Identification
The Synology DiskStation DS218play is a two-bay Network-Attached Storage device. A Network-Attached Storage device is a file-level (as opposed to block-level storage) computer data storage server that is connected to a computer network. The device provides data access to a group of clients and is specialized for serving files either by its hardware, software, or configuration. NAS systems are often produced as computer appliances produced with specialized purposes. Network-attached storage systems remove the responsibility of file serving from other servers on the network.
The Synology DiskStation DS218play includes the name “Synology” on the side of its rectangular body.
Technical Specifications
CPU: Realtek RTD1296 64-bit 4-core 1.4 GHz
Hardware Encryption Engine: Yes,
Hardware Transcoding Engine:
10-bit H.265 (HEVC), MPEG-4 Part 2, MPEG-2, VC-1;
maximum resolution: 4K (4096 x 2160);
maximum frame rate per second (FPS): 60
System Memory: 1 GB DDR4 non-ECC
Drive Bays: 2 (Hot Swappable Drive)
External Ports
RJ-45 1GbE LAN Port 1
USB 3.0 Port 2
Appearance
Size (Height x Width x Depth) 165 mm x 100 mm x 225.5 mm
Weight 0.87 kg
System Fan 92 mm x 92 mm x 1 pcs
Additional Information
Author
with
Sébastien
4,867 Reputation
6 Guides authored
AEM (ANIMA EX MACHINA) Member of AEM (ANIMA EX MACHINA)
Business
1 Member
72 Guides authored
Past 24 Hours: 9
Past 7 Days: 24
Past 30 Days: 75
All Time: 1,993
