Studio Display Teardown: Is this secretly an iMac?
1 Answer 1 Score |
Swap from stand to VESA mount |
2 Answers 3 Score |
Cracked screen, any way to fix? |
1 Answer 1 Score |
Why are my USB-C ports buzzing when used? |
2 Answers 0 Score |
Replace Apple Studio Display screen with iMac 5k screen possible? |
Documents
Identification and Background
The Studio Display was announced on March 8th, 2022 and released March 18th, alongside the Mac Studio. Marketed as the companion screen to the Mac Studio, the Studio Display features a 27-in 5K display with a 5120x2800 resolution and 600 nits of brightness. It also boasts a 12MP Ultra Wide camera, a six-speaker system, three-mic array, and A13 Bionic chip integration, which enables features like Center Stage and “Hey Siri.”
The Studio Display currently comes in Standard Glass and Nano-texture Glass variants, the latter offering light scattering to minimize glare; they are priced $1,599 and $1,899, respectively. Similarly, the Studio Display has three options for stands at checkout: Tilt-adjustable, Tilt- and height-adjustable, and VESA mount adapter. They all do what their name implies—the VESA mount adapter works with any VESA-compatible 100 x 100 mm mount—and the Tilt- and height-adjustable stand is an additional $400.
The Studio Display received a hardware refresh in March 2026, which upgraded two of the four USB‑C ports to Thunderbolt 5 (up from a single Thunderbolt 3 port on the original).
Technical Specifications
Models:
- Screen:
- Standard glass
- Nano-texture glass
- Stand:
- Tilt-adjustable stand
- Tilt-and-height-adjustable stand
- VESA mount adapter
Size and Weight:
- Studio Display w/ tilt- and height-adjustable stand:
- Bottom position: 18.8 in (47.8 cm) x 24.5 in (62.3 cm) x 8.1 in (16.8 cm)
- Top position: 23.0 in (58.3 cm) x 24.5 in (62.3 cm) x 8.1 in (20.7 cm)
- 16.9 lbs (7.7 kg)
- Studio Display w/ tilt-adjustable stand:
- 18.8 in (47.8 cm) x 24.5 in (62.3 cm) x 6.6 in (16.8 cm)
- 13.9 lbs (6.3 kg)
- Studio Display w/ VESA mount adapter
- 14.3 in (36.2 cm) x 24.5 in (62.3 cm) x 1.2 in (3.1 cm)
- 12.1 lbs (5.5 kg)
Display:
- 5K Retina display
- 27-inch (diagonal) 5K Retina display
- 5120x2880 resolution at 218 pixels per inch
- 600 nits brightness
- Support for 1 billion colors
- Wide color (P3)
- True Tone technology
Reference Modes:
- Apple Display (P3-600 nits)
- HDTV Video (BT.709-BT.1886)
- NTSC Video (BT.601 SMPTE-C)
- PAL and SECAM Video (BT.601 EBU)
- Digital Cinema (P3-DCI)
- Digital Cinema (P3-D65)
- Design and Print (P3-D50)
- Photography (P3-D65)
- Internet and Web (sRGB)
Camera:
- 12MP Ultra Wide camera with 122 degrees field of view
- ƒ/2.4 aperture
- Center Stage
Audio:
- High-fidelity six-speaker system with force-cancelling woofers
- Wide stereo sound
- Support for Spatial Audio when playing music or video with Dolby Atmos
- Studio-quality three-mic array with high signal-to-noise ratio and directional beamforming
- Support for “Hey Siri”
Ports:
- Original model:
- 4x USB‑C ports, one with Thunderbolt 3 (up to 40Gb/s)
- 2026 model:
- 4x USB‑C ports, two with Thunderbolt 5 (up to 120Gb/s)
- The upstream Thunderbolt 5 port is labeled with a dot symbol (•)
Stand:
- Tilt-adjustable stand:
- Tilt: −5 to +25 degrees
- Tilt- and height-adjustable stand:
- Height adjustment: total of 105 mm
- VESA mount adapter:
- Compatible with 100 x 100 mm VESA stand or mount
- Orientation: landscape or portrait
Compatibility:
- Mac Models (running macOS Monterey 12.3 or later):
- Mac Studio (2022)
- 16-inch MacBook Pro (2019 or later)
- 14-inch MacBook Pro (2021)
- 13-inch MacBook Pro (2016 or later)
- 15-inch MacBook Pro (2016 or later)
- MacBook Air (2018 or later)
- Mac mini (2018 or later)
- Mac Pro (2019 or later)
- 24-inch iMac (2021)
- 27-inch iMac (2017 or later)
- 21.5-inch iMac (2017 or later)
- iMac Pro (2017)
- iPad Models (running iPadOS 15.4 or later):
- iPad Pro 12.9-inch (3rd generation or later)
- iPad Pro 11-inch
- iPad Air (5th generation)
Electrical and Operating Requirements:
- Line voltage: 100–240V AC
- Frequency: 50Hz to 60Hz, single phase
- Operating temperature: 50° to 95° F (10° to 35° C)
- Relative humidity: 5% to 90% noncondensing
- Maximum altitude: tested up to 16,400 feet (5000 meters)
