Medical Equipment
Neither iFixit nor this repair information is endorsed by or affiliated with the medical device manufacturer.
No Image
This wiki is missing a device image. Help improve this page by uploading one!
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background and Identification
The Steris Eagle Century Millennium is a steam sterilizer produced by Steris Corporation. Founded in 1985, Steris Corporation is an Irish medical equipment company that specializes in sterilization and surgical products for the U.S. healthcare system. Steris produces steam sterilizers also known as autoclaves, which are a vital aspect of the decontamination and sterilization process performed by sterile processing departments in healthcare facilities. Steris sterilizer machines can eliminate living organisms such as bacteria, fungi, viruses, and spores.
The Steris Eagle Century Millennium is made from stainless steel and is sold in various models, including one with single doors and one with double doors. It includes touch-sensitive control and cycle safeguards to prevent incorrect temperature parameters.
Some common issues or alarms in Steris Sterilizers include the following:
  • Aborted cycles
  • Air utility failure alarm (evolution products)
  • Bowie-Dick failure
  • Display Screen
  • Model 0 or 1 Alarm
  • Noisy Operation
  • No Power
  • Printer Fault
  • Steam leaking from door
  • Steam utility failure alarm for facility supplied steam sterilizers
  • Too long in charge alarm
  • Under temperature alarm
  • Unit not operational
  • Water utility failure alarm
To find out about the potential causes for these issues and to take corrective measures, please refer to the Quick Troubleshooting Guide by Steris.
Technical Specifications
MODEL: Millennium Sterilizer
CHAMBER COMPOSITION: Stainless steel
POWER NEEDED:
  • Vacuum models, vac (POWER NEEDED): 120
  • Gravity models, vac (POWER NEEDED)120
AIR EVACUATION (POWER NEEDED): Steam flush-pressure pulse
RECORDING TYPE (POWER NEEDED): Printer
INSTALLATION:
  • Recessed in the wall (INSTALLATION): Yes
  • In cabinet (INSTALLATION): Yes
  • CONTROLLER (POWER NEEDED): Automatic
DOORS: Single or double
Operation (DOOR(S)): Power
LOADING (INSTALLATION): Rack and shelves or car and carriage
TEMP RANGE, °C (F):
  • Steam flush pressure pulse (TEMP RANGE, °C (F)): 121-132 (250-270)
  • Gravity cycle (TEMP RANGE, °C (F)):121-132 (250-270)
  • Vacuum cycle (TEMP RANGE, °C (F)): 121-132 (250-270)
STEAM PRESSURE NEEDED KG/CM2 (PSIG) (INSTALLATION): 3.5-5.6 (50-80)
CHAMBER DIMENSIONS W x h x d, cm (in) (CHAMBER DIMENSIONS): 40.6 x 40.6 x 66 (16 x 16 x 26), 50.8 x 50.8 x 96.5 (20 x 20 x 38)
Capacity m**3 (ft**3) (CHAMBER DIMENSIONS): 0.109
OTHER ATTRIBUTES (Interference compensation): Touch-sensitive control; printer and paper take-up; cycle safeguards to prevent incorrect temperature parameters; cycle lockout against unauthorized use; automatic utility shutdown. Meets requirements of ASME, CSA, EMC Directive, ETL, Low Voltage Directiv
MARKETING REGION (Interference compensation): USA
Additional Information
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 609
