M.2 SSD Hard drive
1 Answer 1 Score |
No NVMe Detected After RAM/SSD Upgrade on 2026 Steam Machine - lspci C |
2 Answers 0 Score |
How can the internal storage be upgraded? |
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background Information
Announced on November 12, 2025, alongside the Second Generation Steam Controller and the Steam Frame, Valve's second go at the Steam Machine is a compact 6x6-inch Linux-based PC designed to offer an accessible, console-like gaming experience built on SteamOS. The new Steam Machine features a semi-custom AMD Zen 4 CPU and RDNA-3 GPU, which offer more than 6 times the performance power of the Steam Deck. With living-room gaming in mind, the Steam Machine supports 4K at 60 FPS with FSR upscaling.
The Steam Machine (2nd Generation) is offered in either 512 GB or 2 TB SSD configurations; however, both have expandable storage via a high-speed MicroSD card slot. Additionally, users can customize the LED status strip or disable it entirely, and can swap out the front plate.
Valve started shipping 2nd-gen Steam Machines globally in June 2026, with the base 512 GB model priced at $1,049 and the 2TB model priced at $1,349. Steam Controllers can be bundled at a discounted +$79 with either model.
Technical Specifications
General Information
- CPU: Semi-Custom AMD Zen 4 6C / 12T
- Up to 4.8 GHz, 30W TDP
- GPU: Semi-Custom AMD RDNA3 28CUs
- 2.45 GHz max sustained clock, 110W TDP
- RAM: 16 GB DDR5 + 8GB GDDR6 VRAM
- Power: Internal Power Supply, AC Power 110 - 240V
- Storage:
- 512 GB NVMe SSD
- 2 TB NVMe SSD
- Expandable Storage: High-speed MicroSD Card Slot
Connectivity
- Wi-Fi: 2x2 Wi-Fi 6E
- Bluetooth: Bluetooth 5.3 Dedicated Antenna
- Steam Controller: Integrated 2.4 GHz Steam Controller Wireless Adapter
I/O
- Display:
- DisplayPort 1.4:
- Up to 4K@240 Hz or 8K@60 Hz
- Supports HDR, FreeSync, and Daisy-Chaining
- HDMI 2.0:
- Up to 4K@120 Hz
- Supports HDR, FreeSync, and CEC
- DisplayPort 1.4:
- USB:
- Two USB-A 3.2 Gen 1 Ports in the front
- Two USB-A 2.0 High Speed Ports in the back
- Once USB-C 3.2 Gen 2 Port in the back
- Networking: Gigabit Ethernet
- LED Strip: 17 Individually Addressable RGB LEDs for system status and customization
Size & Weight
- Size:
- Height: 152 mm (148 mm without feet) / 5.98 in (5.83 in without feet)
- Depth: 162.4 mm / 6.39 in
- Width: 156 mm / 6.14 in
- Weight: 2.6 kg / 5.73 lb
Software
- Operating System: SteamOS 3 (Arch-Based)
- Desktop Environment: KDE Plasma
