Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
PS4033
Background
The Simpson PS4033 is a pressure washer powered by gasoline. It is designed for cleaning outdoor surfaces such as decks, houses, cars, equipment, among other things. The PS4033 operates on a 212cc Simpson OHV engine and can generate up to 3400 PSI at 3.5 gallons per minute, making it effective for eliminating tough dirt, grease, mold, and other forms of debris. The machine comes with a 25-foot high-pressure hose, which provides ample reach for most cleaning tasks without the need for an extension.
The PS4033 pressure washer also features a direct drive axial cam pump, a 50-foot non-marring high-pressure hose, and an ergonomic spray gun with a downstream detergent injection. It also includes a set of 4 quick-connect spray nozzles for various spray patterns and an onboard nozzle storage. The pressure washer is mounted on flat-free tires for easy mobility, and its steel frame construction includes an integrated handle. A detergent injection system is included for enhanced cleaning performance.
Technical Specifications
  • Model Number: PS4033
  • Product: Simpson Pressure Washer PS4033
  • Product Type: Pressure Washer
  • Engine: 212cc Simpson OHV engine
  • Pressure: 3400 PSI
  • Flow rate: 3.5 GPM
  • Power source: Gasoline
  • Fuel tank capacity: 1.1 gallons
  • High pressure hose length: 25 feet
  • Weight: 111 lbs
  • Pump Type: Direct Drive axial cam pump with thermal relief valve
  • Hose Type: 50 ft. non-marring high pressure hose
  • Spray Gun Features: Ergonomic spray gun with downstream detergent injection
  • Nozzle Type: 4 quick-connect spray nozzles (0°, 25°, 40°, soap)
  • Storage: Onboard nozzle storage
  • Wheel Type: Flat-free tires
  • Detergent System: Detergent injection system
  • Frame Material: Steel frame with integrated handle
Warranty
The Simpson PS4033 pressure washer comes with a limited lifetime warranty on the frame, a 2-year warranty on parts, and a 90-day warranty on accessories. Additionally, the engine carries a 2-year commercial warranty. This warranty coverage ensures that in the case of any manufacturing defects or issues related to the specified parts within these periods, the customer can claim the warranty. To claim the warranty, it is generally recommended to contact the manufacturer's customer support with relevant details such as the product model, purchase date, and a description of the problem. Be sure to keep your purchase receipt or any other proof of purchase safe, as it may be required during the warranty claim process.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 347
