Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
PS3228P-S
Background
The Simpson Pressure Washer PS3228P-S is a gas-operated pressure washer, primarily utilized for intense cleaning purposes of outdoor surfaces, equipment upkeep, and other rigorous cleaning tasks. It is produced by Simpson Cleaning, a company based in the United States, and caters to both consumer and professional demands.
The pressure washer is equipped with a Honda GX200 4-stroke OHV engine, facilitating dependable power for various cleaning tasks. It comprises an AAA industrial triplex pump which generates 3300 PSI at a water flow rate of 2.5 GPM. The product includes a 25 ft MorFlex hose designed to withstand kinking and abrasion. Furthermore, it comes with an ergonomic spray gun outfitted with five quick connect nozzle tips, offering variable spray patterns. The frame of the washer is fabricated from steel, coated with powder for durability, and is set on 10" pneumatic tires for improved maneuverability. The washer measures 34" x 21" x 24" and weighs 77 lbs. It runs on gasoline, with a fuel tank capacity of 0.95 gallons.
Technical Specifications
  • Power: 3300 PSI
  • Water Flow Rate: 2.5 GPM
  • Engine: Honda GX200 4-stroke OHV commercial-grade engine
  • Pump: AAA industrial triplex pump
  • Hose: 25 ft of 5/16" kink and abrasion resistant hose
  • Spray Gun: Ergonomic spray gun with 5 quick connect nozzle tips (0°, 15°, 25°, 40° and soap)
  • Frame: Powder-coated steel frame
  • Dimensions: 34" x 21" x 24"
  • Weight: 77 lbs
  • Fuel Type: Gasoline
  • Fuel Tank Capacity: 0.95 gallons
Warranty
The Simpson Pressure Washer PS3228P-S comes with a multi-tiered warranty plan. The Honda engine has a limited warranty of 3 years, the pump is covered under a limited warranty for 5 years, and the frame is backed by a limited warranty for a substantial 10 years. The warranty for the accessories is valid for 90 days. These warranties are designed to cover any manufacturing defects and flaws. To claim the warranty, it would typically involve contacting the manufacturer, Simpson Cleaning in this case, or Honda for the engine warranty. It is essential to keep all purchase documents safely for warranty claims. Please refer to the user manual or the manufacturer's official website for the detailed procedure.
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 21
All Time: 282
