Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
8 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
MSV3024
Background
The Simpson Pressure Washer MSV3024 is a gas-powered pressure washer designed for residential usage. It is powered by a 212cc Simpson OHV engine and includes an axial cam pump, providing a pressure of 3100 PSI and a flow rate of 2.5 GPM. The machine uses gasoline as a power source, with a fuel tank capacity of 1.1 gallons. It also includes a 64 oz detergent tank for cleaning solutions. The pressure washer's dimensions are 20" x 19" x 40", and it has a dry weight of 68 lbs. For mobility, it is equipped with 10" tubed pneumatic tires.
In terms of usage, the Simpson MSV3024 is designed for a range of home cleaning tasks, such as washing vehicles, boats, patios, decks and other areas around the home. It includes five quick-connect spray tips for varying cleaning applications, and a 25 ft high pressure hose for an ample cleaning radius. The unit also features an all-steel frame with a powder coated finish, built-in hose reel, on-board nozzle and accessory storage, and a method for easy external detergent application.
Technical Specifications
  • Engine: Simpson 212cc OHV engine
  • Pump: Axial cam pump
  • PSI: 3100 PSI
  • GPM: 2.5 GPM
  • Power source: Gasoline
  • Fuel tank capacity: 1.1 gallons
  • Detergent tank capacity: 64 oz
  • Dimensions: 20" x 19" x 40"
  • Dry weight: 68 lbs
  • Wheels: 10" tubed pneumatic tires
  • Hose length: 25 ft high pressure hose
Warranty
The Simpson Pressure Washer MSV3024 comes with a 2-year limited warranty offered by Simpson. This warranty covers any defects in materials or workmanship of major components like the frame, engine, and the pump. It is important to note that items that experience normal wear and tear such as hoses, nozzles, and valves are not covered under this warranty. This warranty is strictly non-transferable, meaning it only applies to the original purchaser of the product.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 25
All Time: 1,296
