Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
MS60773
Background
The Simpson Pressure Washer MS60773 is a gas-powered device designed to assist in household cleaning tasks. It comes equipped with a Honda GCV160 engine and an OEM Technologies axial cam pump, which work together to provide a pressure of 2800 PSI and a flow rate of 2.3 gallons per minute. The device is fueled by gasoline and has a power rating of 160cc. The dimensions of the washer are 23.75 x 18.25 x 36.5 inches, and it weighs 61 pounds.
The Simpson Pressure Washer is primarily used for residential cleaning purposes. It can be utilized to clean stubborn stains off driveways, decks, patios, garages, and sidings among other surfaces. It comes with four quick connect nozzle tips (0°, 25°, 40°, soap) that allow the user to adjust the spray pattern according to the specific cleaning task at hand. Despite its powerful cleaning capabilities, the device is compact and portable, making it convenient to transport and store. The Honda GCV160 engine used in the washer is quieter compared to other engines, contributing to reduced noise pollution. This model meets the emission standards set by the California Air Resources Board (CARB), making it usable in all 50 states.
Technical Specifications
  • Pressure: 2800 PSI
  • Flow Rate: 2.3 gallons per minute
  • Power Source: Honda GCV160 engine
  • Pump: Axial cam pump
  • Power Rating: 160cc
  • Fuel Type: Gasoline
  • Dimensions: 23.75 x 18.25 x 36.5 inches
  • Weight: 61 pounds
Warranty
The Simpson Pressure Washer MS60773 comes with a 2 years limited warranty. This warranty coverage extends to the frame, pump and engine of the product. In order to claim the warranty, you will need to contact the manufacturer, Simpson Cleaning. You should have the necessary details such as product model number and proof of purchase on hand when you reach out to them. Remember that it's important to report any issues as soon as you notice them within the warranty period for the best chance of resolution.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 26
All Time: 519
