Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
MS60763-S
Background
The Simpson Pressure Washer MS60763-S is a gas-powered pressure washer that is suitable for residential use and light-duty outdoor cleaning tasks. The unit is designed to be portable and compact, with a weight of 64 lbs.
The Pressure Washer MS60763-S is equipped with a 196cc Kohler RH265 overhead valve engine and an axial cam pump, capable of providing a pressure of 3100 PSI and flow rate of 2.4 GPM. It also features an easy pull start system and auto shut-off feature. The model comes with a 25ft long, abrasion-resistant hose and an ergonomic spray gun. It is fitted with five quick connect nozzles to adapt to various cleaning tasks. The inclusion of an abrasion-resistant MorFlex hose and ergonomic spray gun aid in the overall functionality and ease of use of the model.
Technical Specifications
  • Model Number: MS60763-S
  • Product Type: Pressure Washer
  • Pressure: 3100 PSI
  • Flow Rate: 2.4 GPM
  • Engine: Kohler RH265 overhead valve engine, 196cc
  • Power Source: Gasoline
  • Pump: Axial cam direct drive pump
  • Hose Length: 25 ft, 1/4" hose
  • Dimensions: 34 x 20.5 x 24 inches
  • Weight: 64 lbs
Warranty
The Simpson MegaShot 3100 PSI Gas Pressure Washer MS60763-S comes with varying warranty lengths for different components. The engine is covered by a 2-year warranty, the pump has a 1-year warranty, the frame benefits from a 5-year warranty, while the accessories carry a 90-day warranty. These warranties cover defects in the materials or workmanship of the respective components. To claim the warranty, consumers would typically need to contact the manufacturer, Simpson, providing details of the issue, proof of purchase, and possibly the faulty component itself, if requested. Always refer to the product's warranty card or Simpson's official website for the most accurate and detailed warranty claim process.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 24
All Time: 342
