Guides
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting
For additional help with the Shark Navigator Lift-Away Zero-M, visit the Troubleshooting Page.
Background
The Shark Navigator Lift-Away Zero-M (ZU560) is a vacuum released in 2019.
There are 10 total vacuums that make up the Shark Navigator Lift Away Zero-M family, with this vacuum marked the end of the ZU560 series.
The most popular models are the ZU560, ZU560C, ZU561, ZU561A, ZU561C, and ZU562, with some lesser known ones including the UV725, CU530, UV725CCO, and ZD201.
All of these are sold around the world except for the ZU562 blue body version, which can only be bought in Canada.
Identification
The Shark Navigator Lift-Away Zero-M takes the shape of a standard up-right vacuum. The model number can be found on a sticker or plate either on the main body or on the detachable canister. The word "Shark" should be clearly visible on the canister along with the word "Lift-Away" being visible on the front end of where the HEPA filter is located.
Technical Specifications
Weight
13-15 pounds
Motor
800 watts
Length
12 inches
Width
9.6 inches
Heigh
45.6 inches
Cord Length
25 feet
Capacity
2.8qt
Vacuum Type
Upright
Additional Information
Consumer Reports: Shark Navigator Lift-Away Zero-M Speed ZU561
Official Shark Navigator Lift-Away Speed (ZU560 Series) Owner's Guide
Amazon Customer Reviews for the Shark Navigator Lift-Away Zero-M Speed
Past 24 Hours: 7
Past 7 Days: 28
Past 30 Days: 106
All Time: 1,905
