Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
PC1010N
Background
The Senco PC1010N is a portable electric air compressor with a 0.5 horsepower motor and 1-gallon tank capacity. It is designed for use with a variety of air tools, including nailers and staplers, making it suitable for finish and trim work. Its compact size and lightweight design, along with a carry handle, enhance its portability, making it suitable for use in different locations.
The air compressor has an oil-free pump and an aluminum tank. It comes with an integrated control panel with clear, easy-to-read gauges and a 1/4 in universal coupler for compatibility with various air tools. It also features an automatic pressure release valve, a motor breaker, and a tank pressure relief valve. The air intake filter is reusable and does not require maintenance. The compressor also has a drain valve for removing moisture after use. It operates quietly at 68 decibels, making it suitable for indoor use. The compressor is powered by a 115-volt corded electric source, with a 6-foot power cord.
Technical Specifications
  • Model Number: PC1010N
  • Product Type: Air Compressor
  • Motor: 0.5 hp induction motor
  • Tank Capacity: 1 gallon
  • Maximum Pressure: 135 psi (9.3 bar)
  • Pump Up Time: 102 seconds
  • Recovery Time: 27 seconds
  • Noise Level: 68 dB
  • Power Source: Corded electric, 115V
  • Power Cord Length: 6 ft (1.8 m)
  • Dimensions: 11 x 14 x 12 in (279 x 356 x 304 mm)
  • Weight: 21 lbs (9.5 kg)
Warranty
The Senco PC1010N air compressor is provided with a 1-year limited warranty. This warranty covers any defects that might occur due to materials and workmanship. In order to claim the warranty, it's important to keep any documentation related to the purchase of the product as it may be required to prove the date of purchase and ownership. However, the document does not provide specific instructions on how to claim the warranty. It is advised to contact Senco or the store where the product was purchased to obtain information about the warranty claim process.
PC1010N 1-Gallon Oil-Free Electric Air Compressor Operating Instructions
Senco PC1010N 1 Gallon Finish and Trim Air Compressor Specifications
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 35
All Time: 450
