Up to 20% off select tools
Guides
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
This page currently covers the 8TB version, although other versions are likely built with the same casing.
12Volt 3Amp DC power input socket on back
USB Micro 3 socket on back
2 Type A USB 2.0 on front
Contains one seagate HDD drive.
In model # SRD0PV1 the drive is an 8 TB 5400 RPM seagate barracuda with Model# ST8000DM004
Warning about internal drive:
Please keep in kind that seagate is able to differentiate between this drive and an equivalent drive sold on its own and that this drive does NOT have a warranty. They will know it was taken from an external bay and will not replace it or recover data for free. I am unsure if this version is less reliable or not so make sure you put it in a raid array to avoid data loss.
Author
with
Spencer Warren
293 Reputation
1 Guide authored
Past 24 Hours: 9
Past 7 Days: 39
Past 30 Days: 147
All Time: 7,987
