Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Samsung WA50F9A7DSP 5.0 cu. ft. Top Load Washer Product Sheet
Background:
The Samsung Washing Machine WA50F9A7DSP is a washing machine meant to do laundry at varying temperatures and speeds to avoid causing damage to the contents inside of it. The machine will chime after its done washing the contents inside it. It is a standard top loading design where all contents go in through the top of the machine instead of the face like the other popular washing machine design.
The machine was part of widespread recall in 2016 due to balance issues with the washing drum. Around 3 million washers in about 30 different models were affected but only specific serial numbers were affected.
Identification:
You can identify the machine as a Samsung by looking in the top left of the control panel where it will say Samsung. This model loads only from the top so if the machine loads from the front it is not a Samsung Washing Machine WA50F9A7DSP. The machine can come in stainless steel, white, or black. It has the control dial in the middle and a settings screen on the right. The serial number is often found on a back panel or the rear of the console.
Technical Specifications:
Dimensions:
- 27 Inches Wide
- 44.75 Inches Tall
- 29.25 Inches Deep
- 142.7 Pounds
- Features:
- Top Loading
- Child Lock
- Soft Close Lid
- Curved Tinted Glass Door
- LED Display
- Direct Drive Inverter Motor
- Stainless Steel Pulsator
- 1,100 RPM Maximum Spin Speed
- Vibration Reduction Technology
- 15 Preset Wash Cycles
- PureCycle TubClean
- Diamond Drum Design
- Smart Care
- AquaJet
- 5.0 Cubic Feet Capacity
- Averages about 165 kWh a year
Helpful Links:
