resistor
1 Answer 3 Score |
Is my panel dead? |
2 Answers 1 Score |
Do I need a power supply or inverter recap? |
1 Answer 2 Score |
Does this monitor work well with DVI->HDMI adapters? |
2 Answers 0 Score |
Anyone know where to get a working bn44-00195a Power Supply Print |
Documents
Tools
Background and Identification
The Samsung SyncMaster 245B is a 24-inch LCD (liquid-crystal display) monitor with a TFT (thin-film transistor) active matrix. The monitor has a resolution of 1920 by 1200 pixels at a frequency of 60 Hertz. Users can adjust the monitor’s brightness, contrast, H/V position, sharpness, color balance, gamma correction, and color temperature. It has a horizontal and vertical viewing angle of 160 degrees.
The Samsung SyncMaster 245B includes a VGA 15 pin HD D-Sub interface, a DVI-D 24+1 pin digital DVI input, and an audio line-out mini-phone stereo 3.5 mm port. The monitor features a security lock slot (the cable lock is sold separately), and the device is wall mountable.
According to a review of the Samsung SyncMaster 245B by Trusted Reviews, the monitor’s 1920 by 1200 resolution gives users a considerable amount of desktop real estate and allows users to have several windows open at once.
The Samsung SyncMaster 245B has a 16mm bezel surrounding the screen with a Samsung logo in the center below the panel and the model number in the top left corner, both in grey font. The monitor controls are located at the bottom right of the device, and a large round power button that glows a blue color is located to the right of those buttons. Next to these, an Auto bottom will automatically adjust the monitor if it is connected to an analog source, though this button is inactive when connected digitally.
Technical Specifications
GENERAL
- Dimensions (WxDxH): 22 in x 9.8 in x 17.5 in
- Display Type: LCD monitor / TFT active matrix
- Aspect Ratio: 16:10
- Native Resolution: 1920 x 1200 at 60 Hz
- Contrast Ratio: 1000:1 / 3000:1 (dynamic)
- Color Support: 16.7 million colors
- Controls & Adjustments: Brightness, contrast, H/V position, sharpness, color balance, gamma correction, color temperature
- Horizontal Viewing Angle: 160
- OSD Languages: English, German, French, Italian, Portuguese, Swedish, Russian, Spanish, Turkish
- Vertical Viewing Angle: 160
- Pixel Pitch: 0.27 mm
- Panel Type: TN
- Brightness: 400 cd/m²
- Horizontal Refresh Rate: 81 kHz
- Video Bandwidth: 154 MHz
- Vertical Refresh Rate: 75 Hz
- Manufacturer: Samsung
CONNECTIVITY
- Interfaces
- 1 x VGA - 15 pin HD D-Sub (HD-15)
- 1 x DVI-D - 24+1 pin digital DVI
- 1 x audio line-out - mini-phone stereo 3.5 mm
POWER DEVICE
- Nominal Voltage: AC 120/230 V
- Frequency Required: 50/60 Hz
- Power Consumption Operational: 100 Watt
POWER
- Power Consumption Stand by / Sleep: 2 Watt
- Power Supply: internal
AUDIO
- Type: Speakers - stereo - integrated
- Output Power / Channel: 2 Watt
INTERFACE PROVIDED
- Qty: 1
- Connector Type: 15 pin HD D-Sub (HD-15), 24+1 pin digital DVI, mini-phone stereo 3.5 mm
MISCELLANEOUS
- Microsoft Certifications: Certified for Windows Vista
- Features: Security lock slot (cable lock sold separately), wall mountable
- OSD Languages: English, French, German, Italian, Portuguese, Russian, Spanish, Swedish, Turkish
- Controls & Adjustments: H/V position, brightness, color balance, color temperature, contrast, gamma correction, sharpness
- Color: black
- Flat Panel Mount Interface: 200 x 100 mm
DISPLAY
- Image Brightness: 400 cd/m2
- Image Aspect Ratio: 16:10
- Image Contrast Ratio: 1000:1
- Color Support: 24-bit (16.7 million colors)
- Type: LCD monitor
VIDEO
- Video Output: none
ENVIRONMENTAL STANDARDS
- EPEAT Compliant: EPEAT Silver
- ENERGY STAR Certified: Yes
VIDEO INPUT
- Digital Video Standard: Digital Visual Interface (DVI)
MECHANICAL
- Display Position Adjustments: Height, swivel, tilt
AUDIO OUTPUT
- Form Factor: integrated
ENVIRONMENTAL PARAMETERS
- Min Operating Temperature: 50 °F
- Max Operating Temperature: 104 °F
- Humidity Range Operating: 10 - 80%
DIMENSIONS & WEIGHT
- Width: 22 in
- Depth: 9.8 in
- Height: 17.5 in
- Weight: 18.52 lbs
HEADER
- Brand: Samsung
- Product Line: Samsung SyncMaster
- Model: 245B
- Compatibility: Mac, PC
PROJECTOR
- Max V-Sync Rate: 75 Hz
- Max H-Sync Rate: 81 kHz
CABLE DETAILS
- Type: VGA cable
- Included Qty: 1
TV TUNER
- TV Tuner Presence: No
Additional Information
- Samsung SyncMaster 245B Support Page
- Samsung SyncMaster 245B Monitor Specifications
- Trusted Reviews: Samsung SyncMaster 245B Monitor Review
Samsung SyncMaster 245B Power Supply BN44-00173A Schematic
SyncMaster 245B / 245BW Εγχειρίδιο χρήσης
Samsung SyncMaster 245B / 245BW Monitor Manual
Samsung SyncMaster 245B/245BW Monitor Manual
SyncMaster 245B / 245BW — руководство пользователя
Samsung 245B and 245BW LCD Monitors (LHU24BS Chassis) Service Manual
Samsung 245B, 245BPLUS and 245BW LCD Monitors (LHU24BS Chassis) Service Manual
SyncMaster 245B / 245BW Monitor Handbuch
Samsung SyncMaster 245B/245BW Navodila za uporabo
Samsung SyncMaster 245B/245BW Manuale d'uso
SyncMaster 245B/245BW Príručka k monitoru
Samsung SyncMaster 245B/245BW Manual de utilizare
SyncMaster 245B/245BW Brukerveiledning
Samsung SyncMaster 245B / 245BW naudojimo vadovas
Samsung SyncMaster 245B/245BW instrukcja obsługi
Samsung SyncMaster 245B / 245BW használati útmutató
Samsung SyncMaster 245B / 245BW Εγχειρίδιο χρήσης
SyncMaster 245B / 245BW monitori kasutusjuhend
Samsung SyncMaster 245B/245BW Uživatelská příručka
Samsung SyncMaster 245B/245BW Priručnik za monitor
Samsung SyncMaster 245B / 245BW - Ръководство за монитора
