Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background and Identification
The Samsung SyncMaster 205BW is a 20-inch liquid-crystal display (LCD) widescreen monitor produced by Samsung and released in 2007. Samsung Electronics Co., Ltd is a South Korean electronics company that is the world’s largest manufacturer of consumer electronics by revenue. In 2020, Samsung announced that it was exiting the LCD business. The Samsung SyncMaster 205BW features a resolution of 1680 by 1050 pixels.
The Samsung SyncMaster 205BW includes a slim silver bezel surrounding the screen. The monitor also includes full vertical adjustment with damped movement that makes it easy to position the monitor at varying heights. It has a VGA 15 pin HD D-Sub port and a DVI-D 24+1 pin digital DVI port. The DVI port is HCDP compliant. Six buttons are located on the bottom right corner of the monitor’s bezel with the power button featuring a blue light. An Auto Configure button is included for using the analog D-SUB input, a Menu button, up and down buttons, and a Select button. The down button also acts as a MagicBright shortcut that gives the user five defaults to choose from — Text, Internet, Game, Sport, and Movie.
According to a review of the Samsung SyncMaster 205BW by Trusted Reviews, the 205BW model has a slightly lower response time than the 215TW model at 6ms compared to 8ms. (The 215TW model is considered the 205BW’s big brother). The 205BW model uses an 8-bit panel that includes 16.7 million colors at its disposal.
Technical Specifications
GENERAL
  • Dimensions (WxDxH): 18.5 in x 7.9 in x 13.9 in
  • Display Type: LCD monitor / TFT active matrix
  • Aspect Ratio: 16:10
  • Native Resolution: 1680 x 1050 at 60 Hz
  • Contrast Ratio: 700:1
  • Color Support: 16.2 million colors
  • Controls & Adjustments: Brightness, contrast, H/V position, sharpness, color balance, gamma correction, color temperature
  • Horizontal Viewing Angle: 160
  • Vertical Viewing Angle: 160
  • Pixel Pitch: 0.258 mm
  • Panel Type: TN
  • Brightness: 300 cd/m²
  • Screen Coating: Anti-reflective, anti-static
  • Horizontal Refresh Rate: 81 kHz
  • Video Bandwidth: 162 MHz
  • Vertical Refresh Rate: 75 Hz
  • Manufacturer: Samsung
CONNECTIVITY
  • Interfaces
    • 1 x VGA - 15 pin HD D-Sub (HD-15)
    • 1 x DVI-D - 24+1 pin digital DVI
POWER DEVICE
  • Power Consumption Operational: 75 Watt
POWER
  • Power Consumption Stand by / Sleep: 2 Watt
  • Power Supply: internal
INTERFACE PROVIDED
  • Qty: 1
  • Connector Type: 15 pin HD D-Sub (HD-15), 24+1 pin digital DVI
MISCELLANEOUS
  • Microsoft Certifications: Certified for Windows Vista
  • Controls & Adjustments: H/V position, brightness, color balance, color temperature, contrast, gamma correction, sharpness
  • Color: silver
  • Flat Panel Mount Interface: Yes
DISPLAY
  • Image Brightness: 300 cd/m2
  • Image Aspect Ratio: 16:10
  • Image Contrast Ratio: 700:1
  • Color Support: up to 16.2 million colors
  • Type: LCD monitor
VIDEO
  • Video Output: none
ENVIRONMENTAL STANDARDS
  • ENERGY STAR Certified: Yes
SOFTWARE / SYSTEM REQUIREMENTS
  • Included Software: Drivers & Utilities, Natural Color, MagicTune
VIDEO INPUT
  • Digital Video Standard: Digital Visual Interface (DVI)
MECHANICAL
  • Display Position Adjustments: Swivel, tilt
DIMENSIONS & WEIGHT
  • Width: 18.5 in
  • Depth: 7.9 in
  • Height: 13.9 in
  • Weight: 14.99 lbs
HEADER
  • Brand: Samsung
  • Product Line: Samsung SyncMaster
  • Model: 205BW
  • Compatibility: Mac, PC
PROJECTOR
  • Max V-Sync Rate: 75 Hz
  • Max H-Sync Rate: 81 KHz
CABLE DETAILS
  • Type: VGA cable
  • Included Qty: 1
  • Length: 6 ft
SOFTWARE
  • Type: Drivers & Utilities, MagicTune, Natural Color
TV TUNER
  • TV Tuner Presence: No
Additional Information
Samsung SyncMaster 205BW 用户手册
SyncMaster 205BW/204BW Monitor Manual
SyncMaster 205BW Monitor User Manual
Samsung SyncMaster 205BW/204BW — Руководство пользователя
Samsung 205BW Fashion Feature LCD Monitor Service Manual
SyncMaster 205BW Manual do Utilizador
SyncMaster 205BW Посібник користувача
Samsung SyncMaster 205BW Monitor Manual del usuario
SyncMaster 205BW/204BW Manual de usuario
Samsung SyncMaster 205BW/204BW — Uporabniški priročnik
Samsung SyncMaster 205BW/204BW kasutusjuhend
Samsung SyncMaster 205BW Monitör Kullanım Kılavuzu
Samsung SyncMaster 205BW — Brugervejledning
Samsung SyncMaster 205BW/204BW Manual
Samsung SyncMaster 205BW/204BW rokasgrāmata
Samsung SyncMaster 205BW/204BW Manual do utilizador
Samsung SyncMaster 205BW/204BW Monitor Manual
Samsung SyncMaster 205BW/204BW Manuel d'utilisation
SyncMaster 205BW/204BW Brukerveiledning
Samsung SyncMaster 205BW 使用手冊
SyncMaster 205BW monitoriaus naudojimo instrukcijos
Samsung SyncMaster 205BW/204BW Használati útmutató
Samsung SyncMaster 205BW/204BW — Manuale utente
Samsung SyncMaster 205BW — Manuale utente
Samsung SyncMaster 205BW Käyttöopas
Samsung SyncMaster 205BW: návod k použití
Samsung SyncMaster 205BW Guide d'utilisation
Samsung SyncMaster 205BW Benutzerhandbuch
Samsung SyncMaster 205BW/204BW korisnički priručnik
Samsung SyncMaster 205BW 대한민국 전용 모니터 사용 설명서
Samsung SyncMaster 205BW/204BW 用户指南
Samsung SyncMaster 205BW Használati útmutató
Author
with
Sam Goldheart
478,971 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 50
All Time: 6,913
