Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Background
The Samsung RF24BB6900** is a refrigerator model in the Samsung range. It is not compact or built-in and does not have a through-the-door dispenser or ice maker. The model is not designed to be counter-depth and has dimensions of 70.0 inches in height and 35.8 inches in width. The total volume capacity is 23.6 cu. ft., and the adjusted volume is 28.8 cu. ft. It uses 627 kWh/year, which is 5% less energy use than the US Federal Standard of 656 kWh/year. The refrigerator uses R-600a type refrigerant.
The RF24BB6900** has connected functionality and can connect using Wi-Fi. However, it does not have direct on-premises open-standard based interconnection and the connected functionality has not been tested. The model was made available on the market in 2022 and is marketed in the United States and Canada. The model identifier, as given by ENERGY STAR, is ES_1023593_RF24BB6900**_01042022021850_80104661.
Technical Specifications
  • Brand Name: Samsung
  • Model Number: RF24BB6900**
  • UPC: 887276624280, 887276624297, 887276639819, 88727663982
  • Type: Refrigerator
  • Product Class: 5I - Refrigerator-freezers - automatic defrost wit
  • Defrost Type: Automatic
  • Compact: No
  • Built-in: No
  • Thru the Door Dispenser: No
  • Ice Maker: No
  • Counter Depth: No
  • Height (in): 70.0
  • Width (in): 35.8
  • Capacity (Total Volume) (ft3): 23.6
  • Adjusted Volume (ft3): 28.8
  • Annual Energy Use (kWh/yr): 627
  • US Federal Standard (kWh/yr): 656
  • Percent Less Energy Use than US Federal Standard: 5
  • Refrigerant Type: R-600a
  • Refrigerant with GWP: No
  • Connected Functionality: Yes
  • Connects Using: Wi-Fi
  • Connected Functionality Tested: No
  • Communication Standard Application Layer: Smart Ener
  • Direct On-premises Open-standard Based Interconnection: No
  • Date Available On Market: 2022
  • Markets: United States, Canada
  • CB Model Identifier: ES_1023593_RF24BB6900**_01042022021850_80104661
  • Source: ENERGY STAR
Author
with
eCuration
478,744 Reputation
396 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 6
Past 7 Days: 11
Past 30 Days: 40
All Time: 425
