Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background and Identification
The Connect Home is Samsung's base model of smart routers. It functions both as a Wi-Fi router and a SmartThings Hub, allowing you to extend your Wi-Fi coverage as well as unifying all your SmartThings devices into one control app. While similar in physical appearances to the Connect Home Pro, the Connect Home runs at the slower AC1300 rating of 400Mbps@2.4 GHz and 866Mbps@5 GHz (compared to Pro's AC2600 800Mbps@2.4 GHz and 1733 Mbps@5 GHz).
Technical Specifications
Connectivity:
  • Wi-Fi Standard: 802.11a/b/g/n/ac
  • Wi-Fi Speed: 400Mbps@2.4 Ghz, 866Mbps@5 GHz
  • Bluetooth, ZigBee, and Z-Wave enabled
System Requirements:
  • Wi-Fi network
  • Device running Android or iOS
  • Power: AC100-240V, 50-60 Hz
Size: 4.7" x 4.7" x 1.2" (119 mm x 119 mm x 30 mm)
Weight: 7.4 oz. (210 grams)
Additional Information
Product Page: Samsung Connect Home
Samsung Connect Home and Connect Home Pro User Manual, Rev. 1.1
Samsung Connect Home ET-WV520 Quick Start Guide
Author
with
Arthur Shi
354,348 Reputation
938 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 34
All Time: 1,557
