Up to 20% off select tools
4 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
R181FB
Background
The Ryobi Router 181FB is a tool perfect for everyone, from beginners to experienced woodworkers. With a strong 1.5 horsepower motor, this router can operate at varying speeds between 25,000 and 30,000 RPM. This means you can easily adjust the speed to work with different types of materials, making it great for various projects.
In addition to the performance capabilities, the Ryobi Router 181FB is built with user-friendly features that enhance its functionality. The router has an ergonomic design making it comfortable to hold during long sessions. The precision control offers depth adjustment options and is helpful for detailed tasks like shaping edges, cutting grooves, or creating inlays. The router is compatible with a range of standard router bits and has a base for stability. It's quick-release feature allows for bits to be changed easily. The dust collection port helps collecting debris as you work.
Identification
To identify the Ryobi Router 181FB, its top half of the tool is a blue color with Ryobi logo located on the front. It is a compact, measuring about 13 inches long, 10 inches wide, and 8 inches tall. This model is unique with dual-side handles and lightweight design, weighing less than 20 pounds. The model number, 181FB can be located on the label on the back side of the tool.
Technical Specifications
Depth of Cut:
Plunge Base: 0-2 in.
Fixed Base & D Base: 0-1 1/2 in.
Collet: 1 1/2 in.
Collet Adaptor: 1/4 in.
Peak Horsepower: 2
Ampere: 10 Amps
Input: 120 Volts, 60 Hz, AC only
No Load Speed: 15,000-25,000 RPM
Power Cord: 10ft.
Total Net Weight: 19lbs.
Source:
Ryobi Operator's Manual
Additional Information
Ryobi Technical Support
Router Forums
How to use a Ryobi Router
Ryobi R1801M Router with R181FB Fixed Base Operator's Manual
Ryobi R162K Router (R1801M/R181FB) Repair Sheet
Ryobi RE1803BK Router Repair Sheet
Ryobi R1801M Fresadora con base fija R181FB — Manual del operador
Ryobi RE1802M Fresadora con bases fija, de émbolo y de mango en D — Manual del operador
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 67
All Time: 858
