Up to 20% off select tools
1 Diagram
Documents
Models
RY80942
Background Information
The Ryobi 3300PSI Pressure Washer (Model Number: RY80942) was officially released in 2020 and is currently still for sale new as a power washer for consumers, small businesses, and small construction sites. Ryobi is limited to Home Depot locations in North America only. It uses a Honda GCV190 gas motor with idle down technology.
This device allows the user to clean surfaces and materials with pressurized water. Many people rely on its functions to get their work completed and risk not having deadlines met when these devices go down.
This device has a black and green color scheme with large metal bars holding all the components together which also act as handlebars. These bars fold over the device for storage and transportation. There are large wheels on each side for transportation. There is also a handheld sprayer that is attached to the main unit with a hose.
The number “3300” is printed on a plastic plate in between the handlebars to visually differentiate from their other models. There is also a black label included on all Ryobi outdoor devices with the model number (Ryobi Official FAQ).
There are other gas-powered models of pressure washers Roybi sells ranging from 3000PSI to 3600PSI. They also sell electric models ranging from 1600PSI to 2300PSI.
Source 1: Ryobi Device Official Page
Source 2: Ryobi All Pressure Washer
Technical Specification
Dimensions:
  • Height: 22In
  • Width: 18In
  • Depth: 24.25In
  • Weight: 68In
  • Wheel Size: 10In
General:
  • Pump: Axial Cam
  • Pump Type: Single Maintenance-Free Pump
  • Detergent Tank: Yes
  • Usage: Heavy Duty
  • Flow Rate: 2.3 GPM
  • Pounds per Square Inch (PSI): 3300
Motor:
  • Engine: Honda TM GCV190 4 Stroke Engine
  • Power Type: Gasoline
  • Fuel Tank Size: 0.25 Gallons
  • Motor Size: 187cc Motor
Included in The Box:
  • Pressure Washer
  • 50 ft. High-Pressure Hose
  • Trigger Handle Holder
  • Spray Wand
  • 5-in-1 Change-Over Nozzle (0°, 5°, 25°, 40° & Soap)
  • 4 Cycle Engine Lubricant (SAE 30 or SAE)
  • Trigger Handle
  • Spray Wand
  • Wheels
  • Assembly Hardware
  • Operator’s Manual
Source 2: Home Depot Product Page
Additional Information
Ryobi Device Official Page - This is Ryobi’s product page. This official page should have the most accurate information and specifications.
Home Depot Product Page - This is Home Depot’s official page where the sales of this pressure washer are made. It has accurate specifications and also has many reviews and support questions.
Ryobi Independent Review (Tool Box Buzz) - This is an independent review with accurate information that matches the other specifications. It has personal stories, use cases, and opinions on the product.
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 20
Past 30 Days: 115
All Time: 7,521
