2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
RAP200
Background
The Ryobi RAP200G Airless Paint Sprayer is a device designed to apply various coating materials, such as paint, stain, sealer, and varnish, onto different surfaces. The device is suited for small to medium-sized projects and can be used on a range of materials, including wood, metal, stucco, and concrete.
The paint sprayer is equipped with a 0.5 horsepower electric motor and can generate a spray pressure of up to 3000 PSI. This allows for a spray rate of 0.24 gallons per minute. It features a spray gun with a full trigger, which includes a Reverse-A-Clean spray tip for quick color changing. The device also has onboard storage for the spray gun and paint hose, which measures 25 feet in length, offering extended reach. It operates on a standard 120V power outlet.
Technical Specifications
- Model Number: RAP200G
- Part Number: FBA_RAP200
- Item Weight: 37.4 pounds
- Product Dimensions: 22.8 x 18.9 x 18.7 inches
- Horsepower: 0.5 hp
- Hose Length: 300 inches
- Spray Gun: Full trigger gun with reverse-a-clean spray tip
- Maximum Tip Size: 0.019 inches
- Maximum Pressure: 3000 PSI
- Spray Rate: 0.24 gallons per minute
- Power Source: Corded electric
- Voltage: 120V
Warranty
The Ryobi RAP200G Airless Paint Sprayer comes with a 1-year limited warranty. This warranty is offered by the manufacturer, Ryobi. The warranty covers defects in materials or workmanship for the specified period, under normal use and maintenance. To claim the warranty, you typically need to provide proof of purchase and contact Ryobi's customer service. It's important to note that the warranty may not cover damage due to misuse or abnormal operating conditions.
Ryobi RAP200 Paint Station Tool Operator's Manual (EN, FR, ES)
