Up to 20% off select tools
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Models
P271
Background
The Ryobi P271 is a drill that operates on a cordless basis. This tool is notable for its compatibility with any Ryobi 18V One+ lithium-ion battery. The specifications of the Ryobi P271 include a power source reliant on an 18V One+ lithium-ion battery, a chuck size of 1/2 inch (13mm), a no-load speed of 0-1500 RPM, and 24+1 clutch settings. The drill measures 9.5 x 3 x 7.5 inches and weighs 3.1 lbs without the battery.
The Ryobi P271 has several features including a brushless motor, a 1/2 inch keyless chuck for quick bit alterations, on-board bit storage, an LED light, a 2-speed transmission, an ergonomic grip, and a lightweight design. A hammer function is also available for drilling into concrete and masonry. The P271 is suited for a range of applications such as home DIY, construction, and remodeling tasks. It can drill into a variety of materials like wood, metal, plastic, concrete, and masonry. This tool serves multiple functions including drilling holes, driving screws, and hammer drilling. The keyless chuck enables swift bit changes when transitioning between drilling and driving. The P271 was first introduced in November 2012 as a part of Ryobi's line of One+ 18V cordless power tools, replacing the older P271A model.
Technical Specifications
  • Model Number: P271
  • Product: Ryobi P271
  • Product Type: Drill/driver
  • Power Source: 18V lithium-ion battery
  • Chuck Size: 1/2 inch (13mm)
  • No Load Speed: 0-1500 RPM
  • Torque Settings: 24+1 clutch settings
  • Dimensions: 9.5 x 3 x 7.5 inches
  • Weight: 3.1 lbs without battery
Warranty
The Ryobi P271 comes with a 3 year limited warranty. This warranty generally covers any defects in materials or workmanship, but it's important to consult the specific warranty details provided by the manufacturer. To claim the warranty, it's likely that you will need to provide proof of purchase and contact Ryobi's customer service or warranty department. Some manufacturers may require you to send in the defective product for inspection or repair. Please ensure to follow the specific instructions provided by Ryobi to claim your warranty.
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 47
All Time: 831
