5 Diagrams
No Answers 0 Score |
Why is fuel leaking from the back of the carborator |
Documents
Models
RY906500
Background
This unit runs off of a professional-grade Honda GX390 engine that delivers 6,500 running watts and 8,125 starting watts of power. It can be used at the job site or at home. It was first created around 2019.
Identification
The Ryobi Generator RY906500 has a sturdy hand truck frame, flat-free 10" wheels, an Automatic Voltage Regulator, and a Low Oil Shutdown. It is 39 inches long, 29 inches wide, and 24 inches high. It is mostly black and yellow, and that is the only color it comes in. The model number is found on a label attached to the engine.
Technical Specifications
- Fuel tank capacity: 6 gallons
- Weight: 195 lbs
- There are no USB charging ports on board.
- Outlet Types: 120V 20A, 240V 30A
- 12v battery Charging Leads for Control Panel.
- Engine type: runs off of a professional-grade Honda GX390 engine.
- Wattage: 6500 watts
- Dimensions:
- Length: 35 inches
- Width: 29 inches
- Height: 24.5 inches
Additional Information
It is recommended that the user wear hearing protection when standing close to the unit while it is running.
