Up to 20% off select tools
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
P423
Background
The Ryobi Angle Grinder P423 is a battery-powered angle grinder manufactured by Ryobi. Angle grinders were initially designed for grinding metal. Over time, angle grinders were adapted for other uses, such as polishing and cutting. Different types of wheels and accessories are needed to accomplish these uses.
The Ryobi P423 is part of the ONE+ line of power tool products and accessories. There are two main features of the product line. One of these features is the cordless design, with the tools instead being powered by rechargeable lithium batteries. Any battery made for the ONE+ product line can be used with any ONE+ power tool. The second feature is the brushless motor designed for increased power, runtime, and motor longevity.
A primary feature of the Ryobi P423 is the maneuverable handle. The handle can be placed in three locations. The tool's compact design works in combination with the maneuverable handle to maximize user control while the tool is being used. The handle is also used for storage of an included spanner wrench. The tool additionally features a lock-on switch for user convenience and control.
Identification
The Ryobi P423 uses a fluorescent green and light grey color scheme. The side of the tool as well as the handle are labeled "RYOBI"; the handle label is embedded while the tool label is white text. The side of the tool also has a black "Brushless" label located near the "RYOBI" label. On the base of the battery housing is a grey "ONE+" label. The lock-on switch is located above the "RYOBI" and "Brushless" labels on the tool.
Technical Specifications
Coverage
  • Certifications and Listings: 1-UL Listed
Detail
  • Arbor Size: 5/8 in x 11 UNC
  • Speed: 10,400 RPM
  • Battery: 18V
Dimension
  • Wheel Size: 4 - 1/2 in
  • Tool Weight: 4.35 lbs
Sources
Additional Information
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 41
All Time: 995
