Guides
11 Diagrams
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
WIDE TRACK -95373
Background and Identification
The Rug Doctor Pro Wide Track Carpet Cleaner is an plug-in electric carpet cleaning machine that was released in 2016. It is an extraction cleaner, which means that it uses a vibrating brush to agitate dirt and dust in the carpet, and a vacuum to extract the dirty water and dry the carpet to prevent water damage. The wide track allows the user to cover a larger strip of carpet, making the cleaning time faster. This carpet cleaner is industrial-grade, and users should read the manual carefully to ensure that they use it correctly.
The Rug Doctor Pro Wide Track Carpet Cleaner is advertised to recover about 70% to 80% of the water used in cleaning. The amount of water recovered depends on the carpet that is cleaned, however, so users should take care to ensure that the carpet dries fully by ventilating the room if possible.
Technical Specifications
  • Product Depth (in.): 20.5
  • Product Height (in.): 28
  • Product Width (in.): 13
  • Product Weight (lb.): 44 lb
  • Cord Length (ft.): 22
  • Brush Size (in.): 12
  • Cleaning Tank Capacity (gallons): 3.7
  • Collecting Tank Capacity (gallons): 4.8
  • Operation Style: Push
  • Voltage (v): 120v
  • Amperage (amps):12 A
  • Horsepower (hp): 1.81 hp
  • Noise Level (dB): 72
  • Recommended Surfaces: Carpet
Additional Information
Home Depot Rental Page
Use and Care Manual
Water Extraction Cleaning - Wikipedia
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 2
Past 7 Days: 32
Past 30 Days: 260
All Time: 83,876
