No Answers 0 Score |
Has anyone experienced power issues with a Roland TD-15KV module |
Roland TD-15KV: Real-World Experience, Strengths and Common Issues
The Roland TD-15KV is widely regarded as one of Roland's most successful mid-range electronic drum kits. Released in 2012, it introduced Roland's SuperNATURAL drum engine, offering a more expressive and realistic playing experience than previous generations. Many drummers still use the TD-15KV today because of its durable hardware, reliable triggering, and compatibility with modern drum software such as Superior Drummer and EZdrummer. [edrumhub.com|new_window=true], [cdn.roland.com|new_window=true]
What Users Like
Owners frequently praise the kit's mesh-head pads, which are known for their realistic feel and long lifespan. Several long-term users report years of regular practice without replacing mesh heads, highlighting Roland's reputation for durability. The included VH-11 floating hi-hat is also considered a major advantage over simpler pedal-controlled hi-hat systems. [drummerworld.com|new_window=true], [cdn.roland.com|new_window=true]
Another commonly mentioned benefit is the TD-15's reliability for home practice, rehearsals, and MIDI recording. Despite its age, many users consider it a solid used-market purchase because Roland hardware tends to remain dependable for many years. [drummerworld.com|new_window=true], [edrumhub.com|new_window=true]
Common Complaints
The most frequent criticism is that the factory sounds feel dated by modern standards. While the triggering remains highly respected, many drummers now use the kit primarily as a MIDI controller connected to drum software. [edrumhub.com|new_window=true]
Some users also find the pad sizes relatively small compared to newer electronic drum kits. Although this is not a technical fault, it can affect comfort for drummers accustomed to larger acoustic drums. [drummerworld.com|new_window=true], [edrumhub.com|new_window=true]
Reported Technical Problems
1. Hi-Hat Calibration and Response Issues
The VH-11 hi-hat is one of the most commonly discussed problem areas. Users have reported:
- Open hi-hat hits sometimes being interpreted as closed hits.
- Difficulty achieving smooth transitions between open and closed positions.
- The need for careful calibration of the VH-11 offset settings.
- Reduced responsiveness as components age. [manualzz.com|new_window=true], [drummerworld.com|new_window=true]
2. Hi-Hat Pedal Sensor Wear
Several Roland hi-hat controllers use rubber actuator components that can harden, wear out, or tear over time. Symptoms include:
- Hi-hat not opening or closing correctly.
- Missing foot-chick sounds.
- Complete loss of pedal response.
Users have reported repairing these problems by replacing sensor-actuator parts or the internal rubber mechanism. [reddit.com|new_window=true]
3. Cymbal Trigger Issues
A number of owners have reported crashes occasionally:
- Cutting out during performance.
- Missing hits.
- Triggering inconsistently after years of use.
In many cases, the issue appears related to pad wear, cables, or trigger settings rather than the TD-15 module itself. [reddit.com|new_window=true], [drumsilent.com|new_window=true]
4. Double Triggering and False Triggers
Like many electronic drum kits, some TD-15KV owners report:
- Double-triggered notes.
- Unwanted triggering caused by vibration.
- Crosstalk between pads.
These issues are often reduced through sensitivity, threshold, crosstalk, and retrigger-cancel settings in the module. [drumsilent.com|new_window=true], [roland.com|new_window=true]
5. MIDI and VST Configuration Problems
When connecting the TD-15KV to software such as Superior Drummer, some users have experienced:
- Unexpected velocity behavior.
- Kick drum response inconsistencies.
- Mapping problems requiring MIDI reconfiguration.
Most of these reports point to software setup issues rather than hardware failures. [toontrack.com|new_window=true]
Long-Term Reliability
Overall, the TD-15KV has a reputation for being more reliable than many competing kits from the same era. The most commonly replaced components tend to be hi-hat mechanism parts, cymbal pads, and cables rather than the TD-15 sound module itself. Many units remain fully operational after more than a decade of use. [drummerworld.com|new_window=true], [edrumhub.com|new_window=true]
Bottom Line
If buying a used Roland TD-15KV, the key things to inspect are:
- VH-11 hi-hat operation and calibration
- Cymbal triggering consistency
- Cable condition
- Pad sensitivity and signs of double triggering
- Module firmware version and overall module functionality [roland.com|new_window=true], [manualzz.com|new_window=true]
Despite being an older model, the TD-15KV is still considered a solid and dependable electronic drum kit, especially when found at a reasonable price and paired with modern drum software.
