2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
K-45AF
Background
The Ridgid Drain Cleaner K-45AF is a tool used for the purpose of unclogging various types of drains, such as those found in sinks, tubs, showers, lavatories, and urinals. Its design incorporates an AUTOFEED control which allows users to both advance and retract the cable without altering the motor's direction, thereby maintaining cleanliness in the user's hands and workspace.
The K-45AF's power unit features a motor with variable speed, capable of rotating the cable at rates between 0 and 600 RPM. It is encased in a lightweight plastic housing and the total weight of the unit is approximately 11 pounds. The drain cleaner is equipped with a steel cable, 25 feet long and 5/16" in diameter, which is wound around a plastic drum inside a removable sealed canister. The canister is designed to prevent water leakage and minimize cable tangling. The tool operates on a 120V, 60Hz electric power source. The operation involves placing the base of the unit on the floor near the drain, feeding the cable into the drain opening, and activating the motor to rotate the cable, which then removes the clog. Regular inspections and replacement of the cable and drum are suggested to maintain the tool's performance. The K-45AF is produced by the Ridgid Tool Company, an Ohio-based company that specializes in professional plumbing tools.
Technical Specifications
  • Model Number: K-45AF
  • Product Type: Drain Cleaner
  • Design: Ergonomic with patented two-way AUTOFEED control
  • Power Unit: Variable speed motor (0 to 600 RPM)
  • Housing: Lightweight plastic
  • Weight: Approximately 11 pounds
  • Cable: 5/16" diameter, 25' length steel cable
  • Drum: Interchangeable plastic inner drum in a removable twist lock sealed canister
  • Dimensions: 12 x 7 x 14 inches
  • Power Supply: 120V, 60Hz electric motor
  • Cable Speed: 0-600 RPM
  • Drum Capacity: 25' of 5/16" cable
Warranty
The Ridgid Drain Cleaner K-45AF comes with a warranty period of 3 years. During this period, any defects or malfunctions within the product will be covered under warranty, ensuring that the product performs as expected. If the product fails to deliver its promised function or shows significant signs of wear and tear under normal use within this time frame, a claim can be made under the warranty. To claim the warranty, you would typically need to contact the Ridgid Tool Company directly, providing details about the product, the issue, and proof of purchase. The company should then guide you through the process, which often involves assessment, repair, or replacement of the product or parts thereof.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 25
All Time: 381
