1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Models
OF60150HB
Background
The Rigid Air compressor, is a portable high quality and high grade air compressor, that can be taken with you on the go for all the time you might need it. The compressor comes with dual universal connections that are reliable and maintenance free. Compressors can be used in many great ways for your everyday needs, like filling air in your car tire while you're out on a drive, the handle and the compact size makes it convenient to fit in the trunk. Compressors aren't  just used for filling in with air but also for cleaning dust off places with the pressured air, or using it to paint.
While they have many different functions, compressors come in many shapes and sizes as well. Some compressors are so small they can even fit into a backpack and be taken on the go. As technology advances there's no telling how small and portable compressors can get for consumers convenience.
Identification
The Rigid Air compressor should have a big Rigid logo on the bright orange tank of the compressors, on the top is a black handle with the two universal connectors. It also has another big white Rigid logo. The compressor comes with a large handle to make it easier to carry around, and has a scale for checking how much pressure(PSI) is inside. The tank is made from steel and can hold up to 6 gallons, with a knob on the side for unwanted pressure changes.
Technical Specifications
Body
  • Depth: 17.13 in.
  • Height: 19.75 in.
  • Width: 17.13 in.
  • Weight: 35lbs.
  • Material: Steel and plastic
  • Style: horizontal
  • Tank capacity: 6 gallons
Performance
  • Air delivery SCFM at 40 PSI: 3.5
  • Air delivery sCFM at 90: 2.6
  • Max pressure PSI: 150
  • Decibel Rating (outdoor)80dBA
Electrical
  • Amperage: 12
  • Power Source: Electric
Additional Information
Rigid Offical website
Rigid compressor warrenty
How to setup Rigid Air compressor
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 63
All Time: 1,585
