Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Background and Identification
The Revo RM215-OR1 was introduced in 2011 and is intended to be used with a security system. While it is designed for this purpose and has ports with this in mind, the monitor uses a standard VGA input and can also be used on a PC if you purchase one of these monitors with this intention in mind. It can also be wall mounted, which is accomplished with a VESA mount. The monitor requires a VESA 100x100 mount, if it is wall mounted.
This monitor is typically bundled with a security system set, but was available separately. Most monitors that are found independent of the corresponding security system likely came from a bundle that included this monitor.
To verify this is the monitor you have, check the back of the monitor. The label should say MODEL NO: RM215-OR1.
Ports and Specifications
Note: The Audio Out port may not function on a PC.
Panel specifications
  • Panel size: 21.5"
  • Resolution: 1366x768
  • Panel type: TN
  • Backlight: LED with high voltage driver
Input options
  • VGA
  • Audio In
  • Audio Out
Author
with
Nick
107,129 Reputation
73 Guides authored
Master Techs Member of Master Techs
Community
337 Members
8,294 Guides authored
Past 24 Hours: 5
Past 7 Days: 9
Past 30 Days: 38
All Time: 1,409
