Up to 20% off select tools
Medical Equipment
Neither iFixit nor this repair information is endorsed by or affiliated with the medical device manufacturer.
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background and Information
The Virtuoso LX Smart CPAP System is a black, roughly rectangular plastic box about 10” long by 5.5” wide and 4.75” high. It weighs 3.5 lbs. On one end of the top of the device is a digital screen which is outlined in white, with four round buttons serving various functions. A plug for the hose is found below this screen on the short end of the device. The name of the device is seen directly underneath the digital screen, and a slot holding a memory card resides on the side of the device. No model number is seen on the device.
The predicate device, Virtuoso CPAP System, was replaced in 1999 by this device, the Virtuoso LX Smart CPAP System, which was different due to the addition of a removable data card. This card was the size of a credit card and had two functions: data retrieval and device settings memory.
The Virtuoso LX system was manufactured for the treatment of adult obstructive sleep apnea. The machine is made of a blower-based system that generates positive pressures from 3-20 cm H20. It is intended to be used with a patient circuit that connects to the CPAP device to route air to patients via a nasal mask. This patient circuit is made up of six feet of 20 mm tubing, an exhalation device, and a nasal mask.
Due to its multi-mode operation, the machine can be used all night. The Virtuoso LX is an automatically adjusting CPAP system, which means that it continually monitors the patient's airway and automatically delivers the appropriate pressure for therapy during operation.
The machine keeps the airway open by automatically adjusting the constant positive pressure throughout the breathing cycle. This is achieved by the motor speed adjusting and controlling the pressure, which is regulated by the microprocessor.
This device has been discontinued, and the manufacturer was bought out by a larger company in 2007. Although product support is limited to original instruction manuals and manufacturing has ceased, used units still occasionally appear for sale on medical device websites.
Technical Specifications
Environmental:
Operating Temperature
41– 104⁰F (5 – 40⁰C)
Storage Temperature
 -4 – 140⁰F (-20 - 60⁰C)
Humidity
15 – 95% non-condensing
Outlet Temperature Rise
Shall not exceed 122⁰F (50⁰C) when operating at a maximum ambient temperature of 104⁰F (40⁰C). Note: The outlet temperature rise can be as much as 18⁰F (10⁰C) higher than room temperature measured at the end of a 6 ft. tube.
Atmospheric Pressure
83 – 102 kPascals (Storage: 50 – 102 kPascals)
Elevation
0 – 5,500 ft. (0 – 1.67 km) with three selected ranges available.
Noise level
No specification given because various test instruments, test procedures, and unit operating conditions produce varying results.
Fuses:
Fuses
There are no replaceable fuses.
Physical:
Electrical Safety
IEC 601-1, general safety requirement for medical devices.
Dimensions
10.00” (L) x 5.50” (W) x 4.75” (H) (25 x 14 x 12 cm)
Weight
3.5 lbs (1.6 kg)
Electrical:
AC Input Voltage
93 – 126 VAC; 207 – 264 VAC; 47 – 63 Hz
DC Input Voltage
12 VDC
AC Current Consumption
1.0 A maximum
DC Current Consumption
3.0 A maximum
Power Consumption
80 VA maximum
Class
Class I for units with a 3-prong AC power inlet. Class II for units with a 2-prong AC power inlet.
Type
Type BF
Functions:
Modes
CPAP
Auto-CPAP
Split Night with Auto-CPAP
Ramp:
Note: The Ramp feature is only available in the CPAP mode.
Minimum Ramp Press
4.0 – 20.0 cm H2O
Ramp Resolution
1.0 cm H2O
Ramp Time
0 – 45 minutes
Ramp Time Resolution
5 minute increments
Altitude Compensation:
Pressure Range
83 – 102 kPascals
Settings
Low
(0 – 1,800 ft; 0 – 548 m)
Mid (Medium)
(1,801 – 3,600 ft; 549 – 1,097 m)
High
(3,601 – 5,500 ft; 1,098 – 1,677 m)
Compliance Meter:
Compliance Meter (LCD)
Total Operation Time
Time at Pressure
Percent Memory Remaining
Pressure:
AC Operation
3.0 – 20.0 cm H2O
DC Operation
3.0 – 20.0 cm H2O
CPAP Mode
3.0 – 20.0 cm H2O
Auto-CPAP Mode
Min Pressure Range
3.0 – 20.0 cm H2O
Max Pressure Range
min pressure setting – 20.0 cm H2O
Split Night with Auto-CPAP Mode
3.0 – 20.0 cm H2O
Resolution
1.0 cm
Accuracy
+/- 1.3 cm H2O   or 15% of the indicated control setting (whichever is greater). This tolerance assumes system setup similar to maximum pressure test.
Setting Stability
+/- 1.3 cm H2O over 8 hours
Therapy Memory:
Therapy Memory
Retrievable by Encore Software (version 2.5a or later)
(CPAP Mode)
Min Capacity
9 months
Content
Pressure Setting
Date/Time of Each Use
Duration at Pressure
Ramp Usage
(Auto-CPAP Mode)
''Max Capacity
4.5 months (at 6 hours/night usage)
Content
Pressure Setting
Pressure Summary (peak, mean)
Additional Information
  • Operating Instruction Manual: Sleeprestfully.com is a retail website for CPAP machines and various oxygen needs. Although the product is not currently available on their website, a full color, illustrated user’s guide is.
  • FDA Summary of Safety & Effectiveness: This copy of the manufacturer’s modification request states the intended use and description of the device. Additionally, the device modifications (making this the second generation) are listed. Finally, the letter from the FDA to Respironics okaying the placement of the device onto the market is included.
  • Online forum: Cpaptalk.com is a good place to start out looking for information and opinions from previous and/or current device users. Users can ask questions and look at previous discussions to gather information.
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 35
All Time: 964
